Wine & Spirits Logo
Anonymous Posted on Feb 07, 2013
I have a Single Serve Brewing System SS-700 from Cuisinart. I seem to have lost the manual. Does anyone know how to properly clean this machine?
Anonymous
Level 2:
New Friend:
  • Expert 152 Answers
  • Posted on Feb 07, 2013
Anonymous
Expert
Level 2:
New Friend:
Answers
152
Questions
33
Helped
89280
Points
467
I was able to find you an online copy of the manual for this particular product:
http://www.cuisinart.com/share/pdf/manuals/ss-700.pdf
Cuisinart Keurig turns off
www.fixya.com/support/t5130655-cuisinart_coffee_maker_keeps_shutting
Jun 20, 2010 - There is an "Auto Off" programing capability with this machine that may be the culprit if everything else is working fine. Check the user manual ... SOLVED: My cuisinart coffee maker shuts off after ...
1 answer
Oct 12, 2014
Cuisinart SS-700 single serve coffee maker won't ...
Jun 20, 2012
SOLVED: My Cuisinart coffee maker turns off after ...
Jun 28, 2010
SOLVED: Coffee maker shuts off during brew cycle
Nov 29, 2007
More results from www.fixya.com
My cuisinart kcup coffee maker is filling the cup slow and not completely full. I cleaned with white vinegar several weeks ago . Do you have a suggestion
Doesn't brew a full cup.
Every once in a while an air bubble may get trapped in the water path. Lift off the reservoir, then put it back into place.
Turn off and unplug the brewer for 30 seconds or more. When you plug the brewer back in, be sure to turn the power back on.
The exit needle may be clogged (refer to "Cleaning & Maintenance" page 18).
Clean the K-Cup® holder brewing chamber (refer to "Cleaning & Maintenance"
page 18).
Make sure the water reservoir is properly in place, and perform a Rinse cycle.
De-scale the Brewer (refer to page 20).
If you have repeated the de-scale procedure two times and it is still only brewing a
partial cup, contact Customer Service at 1-800-726-0190.
Cuisinart SS 700 Instruction Booklet
Good luck.
Semper Fi,
Z
2answers
Why does my machine brew coffee very slowly almost dripping instead of brewing at regular cycle?
it might need cleaning solution to use is vinegar pour vinegar in it and turn it on let it fill the pot up hope this works good luck
Does anyone ever get a real answer... every answer is the same you might not want to be a fixya if you don't know what you're talking about waste of time
As the poet said: Nobody ever erected a statue to a critic.
Be it as it may, if you have any questions about the use of scientific and graphic calculators, maths, physics, chemistry, I will do my best to answer them.
The thing you seem to forget is that 99.99999% of the questions have their answers in the user's manual which a few people care to read.
Often the question can be solved by just launching a Google search.
A multitude of questions are not questions at all to wit Toshiba Satellite R10. Where is the question?
2answers
My cuisinart single serve brewing system suddenly says "not ready" continually and I can't turn it off unless i unplug it. Same problem when i plug it back in.
Does't heat up or doesn't get the pressure? do you hear a pumping sound? if yes it means it doesn't heat, if not it means it doesn't pressurise...open it and check for spilled water, corrosion, disconnections.
Cheers
Ss 700 single serve doesn't brew
Try smacking the top of it. (Not kidding)
Need instruction book for Cuisinart Single Serve Brewing System Model # CUISS-700
Here are the instructions to de-scale your Cuisinart SS-700, taken directly from the unit's manual, available here (www.cuisinart.com/share/pdf/manuals/ss-700.pdf):
1. Empty the reservoir.
2. Disable the AUTO OFF and OFF TIME features.
3. Making sure there is no K-Cup in the brewing chamber, fill the reservoir with 60 oz. of undiluted white vinegar.
4. Place a large mug on the drip tray and run a Hot Water cycle. Select the 12 oz. brew size. Discard contents of mug.
5. Repeat the hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
6. Let the Brewer stand for at least four hours while still on.
7. Rinse the water reservoir thoroughly and fill with fresh water.
8. Run another Hot Water cycle. Discard contents of large mug.
9. Repeat hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
10. You may need to perform additional Hot Water cycles if you detect any residual vinegar taste.
Note: If DE-SCALE is still displayed on the control panel after completing the procedure, repeat the de-scaling procedure above.
If you found this solution helpful, please leave a positive rating!
Top Wine & Spirits Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Don A
Don A
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
