Have you Cleaned your computer up recently, removed the junk, toolbars, malware, etc? TRY CCLEANER FREEWARE at :
http://www.filehippo.com/download_ccleaner/ This will clean the junk from your computer and in the TOOLS section, STARTUP, disable ALL unnessary STARTUP programs, this will speedup your machine.Disable ALL toolsbars in the same section in INTERNET EXPLORER. ALSO , MALWAREBYTES Freeware at:
http://www.filehippo.com/download_malwarebytes_anti_malware/, Run a FULL SCAN, depending on the size of your HDD may take hours, DELETE ALL RESULTS and Reboot. Run a FULL SCAN with your UP-TO-DATE Anti Virus, delete all results. Then , check ALL connections to device, making sure all cables, change cable to verify, are good and securely inserted. You can remove power and battery fron your device, is this a wireless device or a ISP modem? Plug into AC out let wait for selftest, Any change? If no, Contact your ISP to test signal. You can find the user manual here:
http://www.adtran.com/web/appmanager/portal/Adtran?_nfpb=true&partNumber=1203860G1&productGroupId=9&selectTab=support&_pageLabel=waverunner_page_products_productdetail and Take a look at this Tip:
http://techtips.salon.com/speed-up-downloading-computer-12583.html
