20 Most Recent Adtran NetVanta 3200 Router Questions & Answers
Can't access the internet..
I believe that what you want to do is use DHCP which can assign an IP address, gateway, and DNS server addresses to computers on your network automatically. Many DSL routers include this functionality.
Normally a T1 router does not handle DHCP and the 2824 like most switches does not either. It can act as a DHCP relay but that's a feature typically used for remote locations of larger networks.
There are a couple of different ways to handle this.
1. You may be able to use your old DSL router for this role but only if it will allow you to set the gateway address to an address that doesn't match its own, i.e. the gateway address given to all clients by DHCP must be the internal address of the ADTRAN router.
2. If you have a server like MS Small Business Server then it can handle the DHCP.
3. If neither of the above are practical, you can install 3rd party DHCP server software on a PC. Here's a link to some info on doing this for windows: http://www.tomshardware.com/forum/13577-43-dhcp-server-windows Be aware that if the machine serving DHCP goes down, so will your network after a period of time.
4. I don't recommend using APIPA which is the last ditch method of automatically assigning a 169.254.0.0 network address to PCs when a DHCP server can't be found. You could make this work by giving the router an internal address on the 169.254.0,0 network but you would need to manually configure the gateway and DNS server addresses to make this work.
Regardless of how you handle this, be careful to use a private address range for your side of the router. For a network your size you would normally assign a 192.168.0.0 address with a subnet mask of 255.255.255.0
1/9/2015 6:48:46 AM • Adtran NetVanta... • Answered on Jan 09, 2015
Yellow lan light
Have you Cleaned your computer up recently, removed the junk, toolbars, malware, etc? TRY CCLEANER FREEWARE at : http://www.filehippo.com/download_ccleaner/ This will clean the junk from your computer and in the TOOLS section, STARTUP, disable ALL unnessary STARTUP programs, this will speedup your machine.Disable ALL toolsbars in the same section in INTERNET EXPLORER. ALSO , MALWAREBYTES Freeware at: http://www.filehippo.com/download_malwarebytes_anti_malware/, Run a FULL SCAN, depending on the size of your HDD may take hours, DELETE ALL RESULTS and Reboot. Run a FULL SCAN with your UP-TO-DATE Anti Virus, delete all results. Then , check ALL connections to device, making sure all cables, change cable to verify, are good and securely inserted. You can remove power and battery fron your device, is this a wireless device or a ISP modem? Plug into AC out let wait for selftest, Any change? If no, Contact your ISP to test signal. You can find the user manual here: http://www.adtran.com/web/appmanager/portal/Adtran?_nfpb=true&partNumber=1203860G1&productGroupId=9&selectTab=support&_pageLabel=waverunner_page_products_productdetail and Take a look at this Tip: http://techtips.salon.com/speed-up-downloading-computer-12583.html
12/20/2012 5:24:12 PM • Adtran NetVanta... • Answered on Dec 20, 2012
0answers
Is there a way to
can you not reset it, there should be a small hole at the back of the router
just push the point of a pen in the hole and that should reset it..
11/24/2010 7:05:00 PM • Adtran NetVanta... • Answered on Nov 24, 2010
0answers
I need to configure an
6/17/2010 3:33:29 AM • Adtran NetVanta... • Answered on Jun 17, 2010
Setting timezones on Netvanta 3200 router
clock auto-correct-dst
clock timezone -5-Eastern-Time
clock set 23:58:00 05 May 2010
5/6/2010 6:57:39 AM • Adtran NetVanta... • Answered on May 06, 2010
Can not ping our netvanta 3200 from behind a Linksys nat router
The switch between the NAT routers and the Netvanta had some faulty ports ... the physical connection was broken. Once the switch was replaced, the internet connection was restored.
12/30/2009 2:19:23 PM • Adtran NetVanta... • Answered on Dec 30, 2009
Password apparently lost on Netvana 3200 - any
http://kb.adtran.com/display/2n/articleDirect/index.asp?aid=1786&r=0.6352198
connect console cable
Bootstrap# bypass passwords
Bootstrap# boot
10/23/2009 9:13:33 PM • Adtran NetVanta... • Answered on Oct 23, 2009
Netvanta reset password
Enter admin as the username, enter your admin password, and click the OK button. (The default password is
password.) Here is a link to your manual:
http://www.wedophones.com/Manuals/Adtran/NetVanta%202000%20Series%20Quick%20Start%20Guide%20(Rev%20B)%202nd%20gen.pdf
5/25/2009 1:58:57 AM • Adtran NetVanta... • Answered on May 25, 2009
Configuring remote access
Here is a document which describes this.
Please download, it then:
1. Connect the console.
2. Configure ip address of the router
3. Enable telnet access.
Here is the document location:
http://www.adtran.com/adtranpx/Doc/0/UL9SGGEDF2I4D51F3K4IIEE2FC/61202860L1-13B.pdf
1/12/2009 5:37:44 PM • Adtran NetVanta... • Answered on Jan 12, 2009
If I only had a
have you tried hirens boot cd.../ usb
2/6/2018 6:26:44 PM • Adtran Computers... • Answered on Feb 06, 2018
Adtran NetVanta 3200 Router Logo
25 questions posted
Top Adtran Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Adtran Computers & Internet
Most Popular Question
way
  • Computers & Internet
