Iam trying use netflis on my coby tablet nothing is there any app that i can download
SOURCE: how to download apps on my 7" ematic pro series tablet
Find the "Ematic App Shop" in your list of applications. There isn't a google app store but it does have apps for download. You may need to set up an account before you are able to download the apps, but the shop should give you the instructions. If for some reason you cannot enter your country of origin during the sign-in process, you'll need to install a different App Shop. Go here to find it.
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase
Everything"
The following will occur:
ā¢ The screen will display COBY
ā¢ The screen will display Android
ā¢ The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target.
Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home".
The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until:
1- You have configured your Wi-Fi
2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
