Navman iCN 520 GPS Receiver Logo
David Tollerton Posted on Feb 05, 2013
My navman icn 520 wont find a gps signal and just keeps waiting for gps
My sat nav just keeps waiting for gps and wont find it
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 17, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
460
Points
I found that if you open out the receiver at the back and make sure it is touching the windscreen it works for me. If not I don't get a signal. It is worse in one of our cars because it has a heat reflective windscreen.
5 Related Answers
A
Anonymous
  • Posted on Feb 26, 2008
SOURCE: Navman iCN 520
The CD is not available for download from Navman it seems, but you can get it at thepiratebay.com. Just search for 'navman icn' and you'll find what you need, I just did. Better learn how to download torrents though! :)
Anonymous
  • 818 Answers
  • Posted on Mar 16, 2008
SOURCE: maps for Icn 520
i enclosed the site that can be help you
http://www.maps-gps-info.com/fgpfw.html
Sergio
Anonymous
  • 45 Answers
  • Posted on Apr 10, 2009
SOURCE: my gps won't work
Same solution like here : http://www.fixya.com/support/t906770-no_map_displayed
Anonymous
  • 18 Answers
  • Posted on Aug 31, 2009
SOURCE: continual "waiting for gps " message
the message should also read no mnsa data first... if these units are not in continual use,they get corrupt for some reason. all you can do is hope the gps fix will work itself out,otherwisw buy a new unit.
Melissa Haskell
  • 161 Answers
  • Posted on Dec 29, 2009
SOURCE: need to update the maps on my navman iCN - 510 sat
Go to the home page and use your USB cord and sign in and you should be able to update.
4helpful
Need to update the maps on my navman iCN - 510 sat nav for free
2answers
Navman icn 530
I had this problem when I first started using this product. The key is to make sure you start at your last end point. ie - if you are starting from your house, make sure that you last route ended at your house. Otherwise it has a very hard time determining where you are. Also, you need to sit still while it finds the gps, it continues to look for a position, but has a hard time finding when you are constantly moving. I know it's annoying, but this seemed to help in the long run. Good Luck
1helpful
2answers
Icn 520
I have icn520 - bought an external aerial for it off e-bay now get full strength signal evertytime within seconds - well worth about a tenner rather than ditching the 520 which is was about to do!
It was the windscreen causing the problem for me
2helpful
Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
Navman510
It will take ages to find a signal the first time it tried. Once locked on it should pick up the sats really quickly the next time you turn on the device.
If you turn it off completely (battery switch to off) then it will take ages again the next time it is turned on.
Hope this helps.
Navman iCN 520
Top Navman GPS Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Mike Cairns
Mike Cairns
Are you a Navman GPS Expert? Answer questions, earn points and help others
