20 Most Recent Navman iCN 320 GPS Receiver Questions & Answers
0answers
Memory card
Be the first to answer 10/21/2013 4:46:24 AM • Navman iCN 320... • Posted on Oct 21, 2013Be the first to answer
2answers
Not working
From the Main Menu press the button underneath the spanner>Demo and deselect the first square if it is ticked>Save.
With your device turned off, press and hold the "OK" button in between the arrows and press the "On" button.
On screen you should see the "Maintenance Menu". Scroll to "GPS menu" using the arrow keys and select it using the "OK" button. Select "Perform a GPS cold start". When this has finished, press the "Home" key twice (the one with the three lines on it). Turn the unit off, then go outside, raise the antenna, and turn it on again. Keep it still for 10-15 minutes and the unit will start to pick up GPS again.
10/4/2013 7:10:48 AM • Navman iCN 320... • Answered on Oct 04, 2013
My GPS losses satelite if my MP3 is also connected
I'm thinkin that ur fm transmitter is interfeering with ur satilite signal. solution i suppose would be to purchase head unit that has sat and mp3 plug in capatible... or stop using ur fm transmitter while ur using ur gps.
8/8/2012 12:28:54 PM • Navman iCN 320... • Answered on Aug 08, 2012
How to update
ask mom
6/3/2012 8:21:11 PM • Navman iCN 320... • Answered on Jun 03, 2012
I NEED VALCANO I C 320 DRIVERS
aku mohon zynga aktif kan kembali akun ku yg di has bend aku mohon bandar aku minta tolng zynga i love bandar aku minta tolong
  • aku mohon bandar aktif kan lah akun ku yg di has ben dengan kode:CA3
  • MOHON ZYNGA AKU MINTA TOLONG I LOVE YOU ZYNGA
4/5/2012 2:19:47 PM • Navman iCN 320... • Answered on Apr 05, 2012
2answers
My navman icn 320 keeps searching for gps signal
a few things to ensure
1) battery is fully charged
2) Thed correct BAUD rate and PORT are set ( see manual)
3) You are oiutside and there is a clear view of the sky.
Still failing? Then possible damaged SIIRF chip caused by starting engine while plugged into power socket
Please rate my help++++Thanks for using FIXYA
12/14/2011 9:12:22 AM • Navman iCN 320... • Answered on Dec 14, 2011
How to get my navman reset to factory settings
how do i reset my navman icn 320
2/14/2011 3:00:17 PM • Navman iCN 320... • Answered on Feb 14, 2011
Hi can not pick up any signal. New Zealand.
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
1/21/2011 12:52:01 PM • Navman iCN 320... • Answered on Jan 21, 2011
I bought a second hand
Press and hold the on/off button for ten seconds. This will re-set the system. Do the hard reset by this way "Hard reset by pressing and holding the power button for around 10 seconds, then releasing it and pressing it again for around 10 seconds to turn it back on". Its a painful one but its the temporary solution which you can do.
Let us know if you are looking for something more else accept the suggestion.
Thank You for contacting Fixya.com
3/20/2010 4:25:21 AM • Navman iCN 320... • Answered on Mar 20, 2010
Navman just searches for GPS
i get the same on two of the same here only thing i can say is their tech support does not work and their customer service is next to none but perhaps they have turned off the satelite signal so that the 320's wont work anymore so that people have to go out and buy another 1 or perhaps the aliens shot down the satelite
2/1/2010 6:11:20 PM • Navman iCN 320... • Answered on Feb 01, 2010
I have just brought a navman icn320 sat nav on
mmm Looks like the navman severs down or theres no map card in it.
9/13/2009 8:55:23 AM • Navman iCN 320... • Answered on Sep 13, 2009
How can i update my navman icn320
u need to go to the NAVMAN web site, register your GPS and click support and see if any downloads are avil, there may not be any, if not u will have to wait until they are released.
9/6/2009 4:29:39 PM • Navman iCN 320... • Answered on Sep 06, 2009
I have an only once used Navman ICN320 Gps with
I have not dealt with the ICN320 but as like with most navman gps systems the only sure way to map change is to either buy from navman or check the likes of e-bay.com
7/7/2009 3:42:35 PM • Navman iCN 320... • Answered on Jul 07, 2009
Hi, i have a icn320.
hi, i did what was advised yesterday. i gave the sat nav a trial and so far so good.
6/20/2009 7:02:33 PM • Navman iCN 320... • Answered on Jun 20, 2009
2answers
Can't get updates for ICN 320
I have a ICN 320 Navman and it took 20 to 30 mins to connect to Satalites that is untill yesterday morning when I Updated the Navman Satalite GPS Data if U wish to know what I did please contact me on [email protected]
My ICN 320 now takes a few seconds to conect to Satalite systems/
Regards
Ken
5/8/2009 3:28:53 PM • Navman iCN 320... • Answered on May 08, 2009
Navman iCN 320 GPS Receiver Logo
43 questions posted
Top Navman GPS Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Mike Cairns
Mike Cairns
Are you a Navman GPS Expert? Answer questions, earn points and help others
View Most Popular
Navman GPS
  • Navman GPS
Most Popular Question
get navman reset factory settings
  • GPS
