Yes, that is possible. Here is a simple program that prompts the user to enter the value of the radius, then it displays the circumference.
To name variables use single letter symbols, A, B, C, ...
To enter keywords such as Input and Disp(play) use the sequence [2nd][0] (Catalog) then scroll or press the letter that begins the keyword to go to the top of the list of commands that start with that letter. For other mathematical and non litteral symbols scroll up to go to the end of the catalog and continue to scroll up until you find the symbol.
SOURCE: Trying to enter Chemistry equations and it won't work...
the way i enter my equations is a bit different from what you're doing, i use the fraction button to do division problems, i just feel it makes it easier to read.
anyway, the fraction button is on the far left, 3rd button down (it looks like a white box on top of a line, and below the line is another empty box). press that, and you can type 1.0x10^-14 on the numerator.
it seems that you haven't discovered the EXPONENT button. that button is on the same row as the fraction button, it looks like an x with a white box next to it. press that once you've typed out "1.0x10", and then type -14. the negative button btw is below the fraction button, and looks like this: (-)
press the right arrow twice on the circle thingy at the top of all the keys, and that'll advance you to the denominator. type 2.0x10^-5, using that nifty exponent key. press the equal sign and it'll solve it for you, all in scientific notation (the answer is 5x10^-10). the problem with this calculator is, it won't expand that answer for you with all the decimals and everything, but if its chemistry that shouldn't be a problem.
also, you can certainly use the "x10^x" button on the very bottom of the keypad (its next to the decimal button). by using this key, you won't have to press the exponent button since you can just type in the exponent directly next to the 10.
as for that negative log of 5.6, just input the negative, the log button is right next to the exponent button, and your number and yeah....it's that easy :]
i hope you like this caculator, it has so many functions (have you seen the size of the manual??)
good luck on your chemistry test!
SOURCE: Solver mode in equations part of calculator
Your Solver is a numerical solver not a symbolic one. You have to supply an initial guess at a solution and the Solver finds it. If you suspect, or know, that there are others jut run the solver again supplying the initial guess for each additional solution.
One easy way to locate the roots of an equation is to draw the function (without =0) and see on the graph the approximate values of x where the function vanishes. These approximate values of the roots can be used as initial guesses in the Solver.
SOURCE: graphing syntax error
To draw graphs.
I am enclosing screen captures. The screens you see may not look exactly as on the FX-9750G, but all menu commands you have to execute are accessed by the same key sequences.
This last one is obtained with the Zoom: Auto
SOURCE: how to use the calculator
The variables you have at your disposal in this calculator are
A,
B,C,D,X,Y,M. All of them are accessed by pressing the [ALPHA] key
before the key near which is written the name of the variable. You will
notice that the markings of the symbols accessed with the [ALPHA] key
are of the same color as that of the [ALPHA] key.
You will notice also that there are two = signs.
The one at the bottom right executes the command line. By pressing it you find the result of the expression just entered.
The
other = sign is marked on the body of the calculator with the same
color as the [ALPHA] key. It is located at the top left of the keyboard
(excluding the row with SHIFT, MODE, the navigation buttons)
Example to enter X^2-2X-35=0 you proceed as follows.
Direct access physical keys are in [ ],
[ALPHA] (X) [X to power 2] [ - ] [2] [ * ][ALPHA][(X) [ - ] [3][5] [ALPHA] (=) [0]
Usually
when you enter such an expression it is with the intention of solving
it for X. By default X is taken to be the UNKNOWN. You will be prompted
to enter the value assigned to any other letter symbol (Y, A,B,C,D).
So,
if you want to use the Solve function, you enter the equation you are dealing with, and before pressing anything else, press [SHIFT] [CALC] and
the calculator will ask you a question: "Solve for X?" , and you press
the = sign at the bottom right.
Then you will be prompted for any other non-X letter. Once all non-X variables (if any) are given values, the calculator will return with the solution. You will see on the screen L-R= (should be zero if you are lucky).
SOURCE: I'm just beginning to learn about trigonometric
Try 4 x cos 7 5 . 8 =
The fx-300MS is a more advanced calculator than what the book is describing. It evaluates cosine(x) as cos x rather than x, cos.
I am sorry, I did not pay attention to the model of the calculator. So I gave you an answer for the TI83/84 Plus calculators. What I described is possible for the Casios, All you need is open the program editor, give it a name and enter commands for the input and the display.
