While taking copy or taking print from PC it gives the message of Error #04-002,please provide me the soluiton.
SOURCE: "Internal error - false" when printing on Samsung SCX-4200
Good day Sir, These are the possible causes why your machine print the wrong text.
Problem: The machine prints, but the text is wrong, garbled, or incomplete.
Have a nice day!
SOURCE: problem scanning with samsung scx 4521f
My connection is via a parallel to parallel cable, and I am also having a similar problem. I'm reading that usb to usb cable is the only way it will properly function. good luck with it!
SOURCE: Can't scan documents
For the system to work
completely; you need the print driver, scan driver and smarthru4.
Once you install the scan driver (available on Samsung website); the issue will go away.
Also, another trick; instead of using the smart thru - which is kind of
awkward, download Picasa 3 and if you have installed the scan driver
correctly, you can use Picasa to import the scans by controlling the
printer. It also allws for some other tweaks that are not so easy to
get to in Smart Thru.
In addition to Picasa you can use several other graphic applications to scan the image.
Good luck.
SOURCE: Problems with Samsung SCX-4216F All-In-One Laser Printer?
SCX-4216F could receive fax, but didn't print out faxes. Can anybody help me with this?
