20 Most Recent Samsung SCX-4725FN All-In-One Laser Printer Questions & Answers
DOOR OPEN ERROR MESSAGE SHOWING ON SAMSUNG
Hi there remove the cartridge and clean the internal part. Then insert the ink cartridge and try. If you face same problem then reset the Printer and turn off for 5 minutes. Now again turn on and let me know the result.
11/6/2021 5:52:16 PM • Samsung... • Answered on Nov 06, 2021
3answers
SCX 4725FN - pulling in two sheets at a time, and jamming
Try fanning the paper. In conditions of low humidity, the paper will tend to stick together. Also make sure the feed roller is clean. Use a cloth with some alcohol on it and clean the surface of the feed roller.
11/15/2016 12:42:12 PM • Samsung... • Answered on Nov 15, 2016
Where is the fuser unit
open thru back cover
10/2/2015 7:10:37 PM • Samsung... • Answered on Oct 02, 2015
My scx-4725fn printer doesn't print. and gives the error message what should i do?
what is the error message that it gives you ? the most common on these printers is the paper feed error the machine will not pick up paper. the feed tire is right below the toner system and the feed tire gets dirty and wont feed paper. if this is the case the feed tire needs to be cleaned. you should take it to a dealer for this cleaning because it is hard to get to the whole tire with out knowing what to do.
3/9/2015 3:23:01 PM • Samsung... • Answered on Mar 09, 2015
Warm up please wait......happens for a long time, finally stops at ready and am able to print. After print job printer goes back into the warning up cycle again..for a long time. I have noticed that t
Dear This problem is due to fail or low supply of high voltage. The HVPS and LVPS is one card. try to clean the high voltage contact points and paths. the warm up time will be reduced. Otherwise you need to replace it. Other things you have experienced are normal. Thanks.
3/4/2015 12:30:55 PM • Samsung... • Answered on Mar 04, 2015
Reset samsung 4725 fn
Dear replace the toner chip with a fresh. Thanks.
3/4/2015 12:21:45 PM • Samsung... • Answered on Mar 04, 2015
Printer humming noise
Dear If refilled toner cart used without proper cleaning, the rollers may sticked and jam so motor try to move but could not, make it free or remove the toner cart and hear the moving sound. or you may try with another cart. Else motor or main PBA fails. Thanks.
3/4/2015 12:11:43 PM • Samsung... • Answered on Mar 04, 2015
what error message shows up? with out that we cant help you.
2/2/2015 4:14:00 PM • Samsung... • Answered on Feb 02, 2015
Printer gives error message "install toner"
Hi Steve, The waste toner tank is the gray L-shaped container to the left of the cyan (blue) toner cartridge. Pull on the tab handle and either shake out the waste toner into a deep trash can (VERY messy) or outside into a trash can, then replace the old one if emptied or use a new one. Should be able to get it at a larger office supply store. Hope this helps.
4/25/2014 1:49:36 PM • Samsung... • Answered on Apr 25, 2014
Printer Stopped Responding
See if you can order a new power supply unit for it. The service manual is here: http://servicerepairmanuals.net/printers/samsung-scx-4725fn-digital-laser-mfp-service-manual/ I dont know if you want to go this far into it though.
1/20/2014 1:30:47 AM • Samsung... • Answered on Jan 20, 2014
I can't make a photocopy with my Samsung SCX-4521F
Lots of instructions hereThe initial option listed is shaking the device. Shaking the device is probably not a good idea, though.
10/27/2013 11:28:21 AM • Samsung... • Answered on Oct 27, 2013
0answers
4answers
How do you scan with Samsung SCX-4725fn?
Having encountered this issue, I read the manual. The only way I found it to work was to press scan and then choose the application that you want to use. I normally just choose scan to Paint. Then launch Paint on your pc, Go to File and select From Scanner and Camera and your image will appear in Paint. (not the easiest scan method in the world but it works; I have tried selecting the other applications on the scanner menu but haven't had any success.
6/6/2013 8:19:00 PM • Samsung... • Answered on Jun 06, 2013
Eoj problem
I know this is an old post, but I still feel it will help to post my solution in case anyone else has this problem. I deleted the Samsung 4725fn PCL6 driver from each computer and added a Universal Print Driver from the Samsung website locally to each PC that connected to this printer via the network. So far, the Universal Driver has solved the End Of Job (EOJ) page from printing after each print job. Hopefully this will help someone else.
7/8/2012 1:34:05 PM • Samsung... • Answered on Jul 08, 2012
Samsung SCX-4725FN All-In-One Laser Printer Logo
Popular Tags
110 questions posted
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
SCX Samsung
  • SCX Samsung
Most Popular Question
last page when print
  • Office Equipment & Supplies
