Computers & Internet Logo
serg Posted on Jan 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot get rid of pceu virus on a windows xp pro fujitsu desktop because it has disabled safe mode and I do not have the windows xp cd to reinstall windows and the cd/dvd drive does not work .
As above
Avinash Verma
Level 1:
Habit-Forming:
New Friend:
  • Contributor 11 Answers
  • Posted on Oct 02, 2018
Avinash Verma
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
11
Questions
0
Helped
4577
Points
66
YOu can Download Windows XP ISO from below Link.
Windows XP SP3 ISO Free Download Windows XP SP3 Bootable ISO
Brian Sullivan
Level 3:
  • Fujitsu Master 27,725 Answers
  • Posted on Jan 22, 2013
Brian Sullivan
Fujitsu Master
Level 3:
Answers
27725
Questions
Helped
5670261
Points
79191
Download the SP3 installation ISO. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en xp pro sp3 iso http://www.imgburn.com/ Download the iso also download the imageburn or
http://windows-xp-pro-startup-disk.soft32.com/ Bootable disk for XP Professional. The Windows XP start up disk allows computers without a bootable CD-ROM to perform a new installation of the operating system. Hope this helps.
5 Related Answers
Anonymous
  • 166 Answers
  • Posted on Aug 22, 2008
SOURCE: reinstall windows xp pro
Ok firstly, you will need to get rid of Vista all together before you can Install XP, Use a partition program to do this, You can find a bunch just by typing partition software into google, Delete the main partition that windows is on, Then create a new partition, then format that partition as a Primary partition, I always use the NTFS format just for stability and it can handle larger files than a 32 Bit partition, when you have done that then you need to get a bootable windows xp and I think you have that if set up is starting but hanging. Just go through the windows setup and you will be done. BE AWARE that you will loose everything thats on the drive by doing this so backup what you want to keep before you start, Always an idea to get the XP drivers for the system as well, The Vista drivers WILL NOT work on an XP system
Hope that helps.
If you run into problems then let me know and I will help you with it
Jessie Goss
  • 162 Answers
  • Posted on Aug 03, 2008
SOURCE: Virus Preventing OS Boot-Up/Safe Mode Access
Take your hard drive out and place it in another computer as a slave and run a scan on your hard drive with the other computer.
If your hard drive is ide hard drive. I'm not sure about SATA drives.
If you could get it on a network with a working computer you could run a scan across the network.
I can do it for you if you are able to open your mail and go online and installl some software I recommend. This will enable me to remote control your computer.
Anonymous
  • 1185 Answers
  • Posted on May 23, 2009
SOURCE: Unmountable boot volume or do I need another hard drive ?
Start machine press F8 repeatedly
If it lets you into Safe Mode then go to Programs, Accesories, System Tools, System Restore and try to roll the machine back a week or so
If that does not work you need to find a buddy with a copy of the software and reinstall providing your machine has the Windows sticker on the back or sides giving you the key code
Anonymous
  • 20 Answers
  • Posted on Jun 25, 2009
SOURCE: Dell Dimension 4700 can not install Windows XP
It looks as though when deleting the OS you might have gotten jacked and the rom drivers were lost.
vinhson65
  • 257 Answers
  • Posted on Aug 12, 2009
SOURCE: Mouse/keyboard not responding - Cannot boot in Safe Mode.
You may use the mouse and key board with PS2 plug (not USB). Most of the bios recognise PS2 configuration rather than USB. If it does not help, you can reset Bios by looking to your mainboard manual or looking the reset pins of Bios located on the main. It usually has a jumper on two pins and another one is open. Take off the jumper and put back to the open pin. Wait 2 min, then take off the jumper to original position. The bios was now clear off. If you could not do such complicated procedure, don't worry-take off the CMOS battery out for 2 min, then put back. It does the same clearance of Bios. Good luck
Testimonial: "Thank you for your help. However, it did not solve the problem."
Hi i have aproblem with an e machine D620 i went to the intenet without anti virus the following day i tried to switch it on after putting the password the sceen becomes blank.help me guys.
Try starting up in safe mode, if you can then try installing a good antivirus eg avast and doing a full scan whilst still in safe mode, you may have to load safe mode with networking to get the antivirus.
If that worked then the antivirus, with any luck, will find any viruses on your pc and get rid of them, which hopefully will solve your problem.
If not then reinstall windows.
1. Backup anything you want to keep, assuming you can (ie. in safe mode).
2. Boot from windows cd.
3. Follow instructions.
4. You should have a working computer, copy over any files you backed up earlier.
This is assuming that the problem is a virus, although the reinstall should fix anything software related.
2answers
I am unable to run any program on my pc. It is infected with a virus and anytime i start the pc the virus covers the whole screen within minutes and disable all programs
Try downloading Malwarebytes (malwarebytes.org) and run it. If you can't run it on that computer, get a recovery CD (such as the Ultimate Boot CD for Windows) and use that to try and recover.
1helpful
4answers
I have a virus and cant connect to the internet, how do i connect and get rid of the virus?
I suggest that on the computer you're on now, that you download the free version of Malwarebytes, burn it to CD disk, and install it into the afflicted computer.
The virus you have, sounds Very much, like MS Antivirus! Some other 'cute' names are Windows Anti-Virus, XP Antivirus, Antivirus Pro, Antivirus Pro 2009, and so on. Wait a week, I'm sure there will be plenty more!
Some of the things it does, is not let you connect to the internet. It also doesn't let you access any Administrator options. No Control Panel, No Task Manager, No Windows Explorer, and other administrative tasks.
The free version of Malwarebytes wipes it out!
This link is to Wikipedia.org, and their descriptive page about Malwarebytes Anti-Malware,
http://en.wikipedia.org/wiki/Malwarebytes
This is the download page for the free version of Malwarebytes,
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
Go down to -> Download Now (2.83MB), and click on it.
A small window will come up which has -> mbam-setup.exe <- in it.
Click on Save.
If you do not have your downloads saved to go to your My Documents folder, (Start>My Documents), this downloaded small file will go to your desktop screen.
Have a blank CD-R disk in your burner drive, (CD or DVD), then right-click on the mbam-setup.exe, folder, and click on Copy in the fly-out menu.
Recovery for fujitsu amilo pro
Hi there have u got the recovery disk, if u have run that and reinstall it, if not press F8 then go to safe mode and go to system restore. I hope this helps u.
Hey you posted this earlier i need help!PLEASE!
If you want to reinstall Windows XP from scratch, try this link, it will give you the step by step guide on how to do it.
Note : If you reinstall Windows XP, You will lose you data.
http://lifehacker.com/software/windows/geek-to-live-how-to-format-your-hard-drive-and-install-windows-xp-from-scratch-157578.php
2answers
Safe mode
because of virus you start windows in safe mode an try booting if it work in safe mode > go to run > type= msconfig > disable all in startup, reboot windows see if it works if not please reinstall windows xp.....
1helpful
VIRUS ?
yes this can be viral in nature or just loss of windows integrity, I would back up what you need to do (burn pictures and documents to a cd rom or dvd ) then use the recovery disks to reimage your laptop.
2answers
Windows xp pro
If u an go IN SAFE MODE with admin privileges so install it :
http://rapidshare.com/files/64484485/Trojan_Remover_6_1_.6.2.rar
and scan.The trojan will be delted and just reinstall OS
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
