20 Most Recent
Fujitsu AMILO Pro V1000 Notebook Questions & Answers
Fuzzy screen
Reaset you LCD cable which is connected to the motherboard
Wifi device
Do you have the wireless switch turned on. Most times there is a wireless switch on either side of the laptop or on the front of it. Turn it on and when on it should show a blue light. Also there are a combination of keystrokes that can toggle the wireless on most laptops. Normally you would have to hit the FN (Function Key down at the bottom left portion of the keyboard) + the corresponding key (F1 thru F12) that controls the wireless. The correct key that controls the wireless will normally have the wireless icon )))) on it. Press and Hold the FN key then hit the F1 thru F12 key that controls the wireless. If you watch the screen usually it will say Wireless On or Wireless Off.
How do you configure computer
Usually the laptop just picks it up without any setup, but if it doesn't you may want to head to BIOS and run a Hardware Changes scan or something similar, depending on the version of your BIOS, or try to check the RAM by having the laptop to Count RAM.
Make sure that the new RAM you added is compatible with the system, otherwise it may not see it at all.
How do i restore my
1- go to Bios setup (by pressing Delete at booting)
2- select " load to default configurations (or settings)".
3- save & exit.
Unable to switch wireless operating
Hi
Have you had a look in :- open network and sharing centre change adapter settings to make sure that the wireless has not been disabled
also look in device manager under network devices and double click to get into properties
try to update the driver if that dont work uninstall it restart notebook and hopefully windows will reload the driver and correct the prob
I have to activate
The Fujitsu AMLO Pro, by default doesnot have a blue tooth adapter . If you have ordered the blue-tooth card in the laptop when you ordered then you can switch it on using the wireless key button on the laptop. However if you have not ordered a blue tooth card with the laptop. You can purchase an external USB blue-tooth adapter.
The user manual for you laptop is on the link below for reference
User manual Thanks for using Fixya
Proton
How do i turn the
Providing you havn't wiped the software for the keyboard,then hold down the "FN"key which down the bottom next to the windows key.
then press the fan key which should be one of the "F" keys along the top.
This aplies to all the keys with symbols on.
