Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S 17-85mm IS Lens Logo
Anonymous Posted on Jul 18, 2007
RC-1 wireless remote
I want to buy a RC-1 for my Rebel XT, has anyone any experience with these, will it work for timed exposures, I cant seem to find a data sheet on the net.
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jul 27, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
1078
Points
6
The RC-1 should be compatible with the Rebel XT. It can be set to a 2-second delay or no delay; pressing the button will activate metering, autofocus, and the shutter all at once.
4answers
Canon RC-1 remote
The Rebel XT must be put in Remote Control mode for it to work:
1helpful
My Canon Rebel XT is overexposing shots in the Auto and Program mode by 1 or 2 stops. How do I fix this or compensate for it?
You can go into "exposure compensation" and lower the setting as you desire. It's the button that's half-black/half-white with a plus and minus.
My Canon Digital EOS Rebel XT is overexposing all my shots. How do I adjust this?
You can lower the ISO. You can set the "exposure compensation" to a lower setting.
2answers
Canon Digital Rebel XT auto focus
Auto Focus does not determine exposure. Only sharpness. "Wrong" exposure could be due to the metering mode being set in Spot Metering. Set it back to Evaluative Metering which may improve the overall even exposure of your shots. Test your shots in full auto or P mode. M (Manual) mode will require you to check the exposure setting manually (you can see the indicator in the viewfinder when you half-press the trigger)
10helpful
2answers
Unable to import photos from Rebel XT to iphoto on mac..."busy"
Try changing the "communication" setting on the camera from "PC Computer" to "PTP"
Menu > Tools2 (wrench/hammer/2) Communication = Print/PTP
http://docs.info.apple.com/article.html?artnum=75336
2answers
Canon Rebel XT Does NOT Take Pictures (AF & Exposure seem OK)
I have the SAME problem. I wrote to Canon and they told me to shut off the camera, take the battery out and wait 20 MINUTES! I can't WAIT that long, especially when I'm WORKING! I rely on this camera to work! Its annoying! Then they said if that doesn't work, to SEND IT IN and if its under warranty, they'll fix it for free.. if its NOT, then I have to pay for it. BUt the "technical team" will make the decision.
My new Canon Rebel EOS XT will not work with my external flash. WHY??
Hi , connection from camera to the quantary ps-1 dszflash are compatible the adopter it connect during flash signal.You may return and bring your camera and test what ever compatible.
Blur on night sports pictures
You are probably going to need a faster lens to get pictures like you want, like around the 1.* range. If you have the ASA at 1600 and aperture at the minimum in Av mode, try and keep the exposure time to 1/focal distance. Such as, if you are shooting 200 mm lens then maximum exposure time is 1/200 second. If you zoom out a bit to 50 mm then it may look better too. You may as well turn the megapixels down too because otherwise you'll just see the blur even more, I'd suggest 3.2 megapixels that will look good in 4x6 photos or on the web. Other than that, try and take pictures where the action is coming at you or going away. Get as close as possible too, so that you don't have to zoom as much. At the H.S. football games I go to it seems like they let anyone down near the field who has a big lens.
3answers
Canon Digital Rebel XT, exposure
Use the bracket exposure method. or read the apeture off then up a stop.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
