Garmin nuvi 200W GPS Receiver Logo
Posted on Jan 24, 2009
Acquiring satellites My Garmin 660 is about 18 mos old. No downloads-Will not acquire satellites it just says acquiring satellites and it wont find any
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jan 24, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
2384
Points
16
My friend has the same unit his will only acquire satellites when unit is plugged in the cigarrette lighter
1 Related Answer
Anonymous
  • 40 Answers
  • Posted on Jan 19, 2009
SOURCE: Acquiring satellites
Try this and see if it fixes your problem...follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to try recover from the problem.
1helpful
2answers
Did you try reseting your nuvi?
1helpful
GPSmap 76CSx is not acquiring satellite
Update the unit using Garmins WebUpdater program, this may fix your issue as there was a chipset update that is crucial to acquiring satellites. here is a link to the software http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Fails to acquire satellites. Garmin 310
I'm assuming you mean a Street Pilot c310. If so, here is the link to the unit software from Garmin. Download it and follow the directions. Once you connect your GPS, it will update the device software are hopefully should fix the problem with it acquiring satellites.
Nov 08, 2009 • Garmin GPS
Garmin Nuvi not acquiring satellite
I am having the same problem with my nuvi 350 and its about the same age. I read on another post it may need a new battery but you need to send it to garmin. I am going to contact garmin directly.
2helpful
3answers
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
2answers
Not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
