I used this label printer Tuesday and today I tried to print a label and it goes to green light blinking and nothing will print. I believe it has something to do with the computer set up page will not respond and if i shut the computer down the Brother P-Touch stops blinking and appears to be waiting to print. As soon as I boot up the computer the blinking starts.
SOURCE: P-touch QL-550 Thermal Label Printer: Upgraded to Windows vista - updated drivers, but m...
You can get the driver downloaded here :
www.brother.com/E-ftp/softwin.html
www.nodevice.com/driver/company/Brother/Printer.html
Jay, G
SOURCE: I have a P-touch QL-500
This solution from loquiter worked for me on my Vista PC
loquiter
I am assuming that your hard disk is not actually full. I am guessing that you are running Windows 7. Click through your start menu until you can see the entry to launch your P-touch Editor. Right click on the entry and click "Properties". Click the "Compatibility" tab. Under "Privilege Level" check the box labeled "Run this program as an administrator". (You can do the same for all users of this computer by clicking the button immediately below, labeled "Change settings for all users".) Click OK, and you're done. The next time you launch the editor, you will get a message asking: "Do you want to allow the following program from an unknown publisher to make changes to this computer?" Click yes, and you should be able to edit and print your labels. Of course, all this assumes that you have sufficient privileges to actually edit permissions and run something as an administrator. Hope this helps.
.g_thread_answer
overflow:visible !important;
Was this solution helpful?
