SOURCE: service engine soon light come on
There are TONS of reasons - the first , and least expensive, step is to read the codes that the onboard computer is throwing. Instead of spending a lot of money on a code reader, or wasting money by going to the dealership, find an AUTOZONE (or, sometimes MERCHANT's will offer a "we'll check your CHECK ENGINE LIGHT for free) and they'll give you a generic read of the code(s).
I say "generic" because the computer DOES throw specific codes; the "we'll do it free" places usually don't have the same kinds of super-readers that the dealerships or high-end repair shops own. But, bear with me for a sec....this may save you some money.
If the generic code says, "O2 sensor"....that's not as specific as you'd like (because there are multiple 02 sensors!)...BUT....if ONE sensor is not functioning properly, its a pretty good bet that the other(s) will be failing soon too, since they were all installed at the same time and all were made by the same company, etc.
The "generic" code WILL tell you enough info as to which sensor is bad (the one in front of the converter vs the one behind the converter) so....if THAT is the code, then simply replace both behind or both "in front". Follow?
Now, where you'll typically get the most common code is for low fuel pressure. If you've never changed your fuel filter...that's a good place to start. The "generic" code will indicate "fuel pressure". If you've never changed the filter....see? BUT, a fuel pressure problem could also be as simple as "loose gas cap"! If your generic code says "fuel pressure", then I'd reset the computer (disconnect the battery for a few minutes and re-connect), and while the battery is disconnected, make sure that the gas cap is tight and the little rubber gasket around the cap is in tact.
Keep in mind....a "check engine light" doesn't mean that your computer is throwing codes CONSTANTLY! It means that the computer sensed something at some point while the scan was running and SOMETHING got its attention. "IF" the fuel cap was loose, for example, just re-tightening it will not reset the "check engine light"! You gotta reset the computer (disconnecting the battery is easiest), THEN the light will be off. If the light returns, then the problem was something other than the gas cap.
Taking your time and doing a little on-line research can save you a ton of money! A 2000 is relatively easy to work on yourself...at least SOME of the issues...even if you're not a really techie-kinda person. Take the easy and inexpensive shots first....
Hope this helps.
SOURCE: 2003 Chevy Trail blazer says service engin soon?
you have a trouble code stored. This means the pcm has detected a problem somewhere
SOURCE: 2001 blazer service engine soon light is on
take it to have it scanned if you have a autozone in your area they will do it for free
SOURCE: Rapping/ticking sound in my 2001 Chevy tracker engine.
does it go tick tick tick tick and when it warms up it stops or goes quiet?
its your lifters not getting enough oil
when u change your oil it will stop till that oil gets worn out
you will have to replace the lifters or it can also be a slack oil pump not pumping oil around the engine like it should
SOURCE: I HAVE A 2001 CHEVY BLAZER MY SERVICE ENGINE SOON
The warning lights are telling you that something is malfunctioning. As long as the warning lights are "ON" you can take it to most major auto parts stores and they will scan it for free, and if the guy that scans it has any automotive knowledge, he'll be able to tell you what is wrong and how/ how much to fix it.
Once you get the codes that the computer is giving, it'll be easier to diagnose your problem, and there are lots of guys on the website who'll be more than happy to tell you how to fix it.
