Rgb was working on laptop now dosent work tv connection works with other laptop doesent work anymore with dell laptop
Instructions
SOURCE: My problem is, that my laptop cannot work anymore its internet connection.
Some questions before we get started: -What operating system are you running? -Are you using DSL, cable or dial-up for Internet access? -If you?re using DSL or cable are you plugging your laptop directly into the Internet provider?s box? What is the manufacturer and model of it? -Have you tested your Internet connection to make sure its working? If it?s a phone line can you dial out, if its DSL or cable try connecting another computer to it. -When you plug your Internet cable into your PC does anything appear or change on your screen? Once you give us some more information to work with we can start figuring out what is going on.
SOURCE: can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for
you to connect it that way. DVI/HDMI is a digital signal and if it's a
digital-based display tech TV, then you're better off using that. Also
if the TV does resolution above 1360x768 (i.e. if it does 1080p) you
can get higher resolution by going via DVI/HDMI...
SOURCE: Dell Studio 17 laptop screen stays black
Awesome, I'm glad reseating the lcd cables did the job. Its crazy how the littlest things can cause such a mess sometimes. Your very welcome and when you get the chance, please rate my solution. Hope your weekend is a great one!!
Ben
SOURCE: funtion F8 not working s video from laptop to TV
Before connecting the external monitor,Shut down your computer,connect the external monitor,Restart the computer and the external monitor should load and The FN+F8 should now work.
