20 Most Recent
IBM ThinkPad T40p 2373 Notebook Questions & Answers
My vlc playar is not working?
Download and reinstall VLC Player.Try using VLC as your player. Go to www.google.com andin the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Downloadand install it. It downloads and installs in 3 minutes or so. It'sa very fast player, smooth and it can play just about any type of dvd formatsand media. It's totally FREE.
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
What is the location of the hard drive?
Easy, please search in the bottom or base of notebook, in the right side a screw near to the corner, only you have to remove it and pull, voila, you have the hard drive.
I forgot the password for my t40
Lost Windows password:
- Login as Administrator with no password (try safe mode if you don't see Administrator).
- Login as other user (if other user is availible) and manage users. Must be an administrator.
- Reformat computer.
- Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Coloured lines across the computer
Hook a spare monitor to the video output, if picture okay the LCD panel display will need to be replaced, go to
www.ebay.com type make and model of laptop, refine search to screen. But if both show the same symptom it is the video graphics card.
Free download drivers
The manufacturer website of your computer is the best choice. Get onlineand got to www.google.com In the google search box type: "IBMSupport" or "Lenovo Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.You can also try Driver Guide at:http://www.driverguide.com
Y doesnt my imb start up normal
What is normal? What is it doing?Try the check disk utility.To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /rCheck disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine. If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
How to connect dual monitors to docking station
one monitor you have onto laptop, second monitor connect to laptop connector for external monitor and in menu Start - Settings - Setting panels - "Icon - Viewing" and for this dialog window select folder "Settings" and configure secondary monitor
