I cant hear a sound from the speaker for my g41t-m motherboard elite group
ECS G41T-M v2.0 motherboard supports Intel Core 2 Quad processors, and supports FSB up to 1333MHz
G41T-M features Intel G41 and ICH7 chipsets, by supporting Intel 45nm
processors and Core 2 Quad processors, which provides impressive
performance. Additionally, G41T-M is equipped 2 DIMM DDR2 800 up to 8GB
get sound (and more) drivers here :
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=925&CategoryID=1&DetailName=Feature&MenuID=16&LanID=9
SOURCE: elite group no sound
Please download the latest software drivers for your integrated sound card.
Create a folder on your desktop & name it, Realtek HD Audio.
Click the link listed below & scroll down the page till you see Realtek HD Audio Driver. Realse date, 2007/12/05
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=820&DetailName=Driver&MenuID=7&LanID=9
Click USA download button & save the file in the folder you created. This files name; GeForce6100SM-M2_V1.0A.zip.
Is compressed. You can use windows to uncompress the file or you can download a program called WinZip for free. 45 day use only.
http://www.download.com/WinZip-Self-Extractor/3000-2250_4-10003166.html?tag=similar
After the software is uncompressed run the setup.exe
Re-start your system. Check your sound function.
If this has failed to fix your no sound problem there are other steps that will need to be checked in order to continue.
1. Open control panel, open Sound and audio devices.
Clcik the Audio tab. Make a note of what is listed under, Default device:
2. Click the Voice tab. Check under Default device.
The two shoud have the same name.
3. If nothing was listed in either, (included the info back here).
4. Close the audio software window. Leave control panel open.
5. Open the System icon.
6. System Properties will open, click the hardware tab, click the device manager button.
7. Scroll down till you see Sound, video and game controller.
8. Click the + sign to open.
9. Do you see a yellow ! point?
If you did see a yellow ! point. We know the correct driver is installed & should be working. There for the integrated sound chip is defective. Your board should still be under warranty.
Not sure about ESC's warranty time line.
You can submitt a request for Technical Support by clicking on the link:
http://www.ecsusa.com/ECSWebSite/Support/TechnicalSupport.aspx?MenuID=19&LanID=9
Or you can call EliteGroup 510-226-7333 9am to 6pm PST
Good Luck & kind Regards.
& please vote.
SOURCE: I have a Elite group
Hi Sportsgam990.
Is this your second post? I answered your first one, but since you've posted again, here's the anser again for you.
I'm going to provide you a link in order to download just the network driver. HERE .
Once you get to that link, Click on the icon that moving, and you should save the file to your desktop, and after it saves, go ahead and run it. Let me know if you have any problems.
Thanks
Mark
SOURCE: hello. i need driver for sound
Here's the link, (click here), open the link and select "I Accept the above" and click "Next". On the next page, you'll see all the available lists of the Audio codecs, click one of the "Go" corresponding to your operating system's name i.e. windows xp (32 bit or 64 bit), save the file and install it.
But you have to install Microsoft UAA Bus driver for High Definition Audio, before the Realtek Driver, (click here to download)
Without installing Microsoft UAA bus driver for high definition audio, you'll never be able to install the Realtek High Definition Audio driver.
If you need further help, let me know. Good luck.
Thanks for using FixYa.
SOURCE: motherboard - Elite G41T-M2 my lan
you installed the drivers?
if you do not have CD with drivers, you can download them on this page
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=993&CategoryID=1&MenuID=16&LanID=0
