Hi I recently received an Ipod Nano from a friend and I set it up and everything worked great. I just locked the screen and I can't unlock it. I called my friend and he said that he forgot the 4 digit combination. Does anyone have a quick fix for this?
From the link Noggin posted I was able to unlock my iPod: Here is some brief explanation: 1. Connect iPod to your computer, it have to be the same one you used the first time to sync your iPod. 2. open iTunes. 3. disconnect iPod from the computer 4. It should no longer be locked. 5. Change the 4 digit passcode If this doesn't work you will have to restore it back to factory settings: 1. Make a backup, the restore process will delete all your songs and files! 2. Connect your iPod to the computer and wait until your itunes detects it. 3. Click the restore button and follow the instructions. * I have never done the restore process so I cannot help you further...
I had the same problem and looked all over the internet and saw those same answers. Ok that won't work. This is what you need to do. I have Vista by the way.
1)connet ipod to computer
2)open itunes
3)got to top of page, click on the store drop down menu and click "authorize computer"
4) next you need to go start menu and click on my computer
5) click on your ipod
6)open the folder that says ipod controls. (This is where I got lost- if you don't see it you need to switch it to classic view- go to organize and click the folder and search options. Under the general tab switch it to windows classic folders. then click the ipod contols option
7) you will see a folder that says "locked". right click it and change "locked" to "unlocked". Thats it.
pretty simple when you do it, you won't lose anything on your ipod. hope it helps you.
Ok here is the solution for unlocking ur apple ipod
1- click on ur ipod folder
2-next click on ipod control folder (which is hidden just make it unhide)
3-next click on device folder .in device folder there will be a file named _locked .just delete that file and ur ipod will be unlocked .....
Ok plugging it into your computer wont help i locked mine and i cant remember my password and it is plugged in now it wont work bc its LOCKED ok im tired of hearing you just need to plug it in u problay need to call itunes and have them help u or u most likely wont fix it ok?
The password would be 1111
You can try the software at www.hiddenvision.co.uk/ipod
I accidently locked my ipod classic and this did the trick for me and I didn't lose any of my files
http://www.youtube.com/watch?v=Au6H_u-q434
Haha i did the same basically go onto your ipod on my computer then go onto ipod control, then device then there should be a file called lock-DELETE IT dw it doesnt mess up ur ipod u can still lock it if u want to. wait for ur ipod to sync then unplug it wolla it should work :D hope this helps it worked for me
Forgot the 4digit combinaton
I just recently like right now locked it by accident if i were you i would go through all of the possible solutions lol could take a while but that how i got my bike chain undone
ex 0001 0002 0003 0004 0005 0006 0007 0008 0009 0010 ect..
I forgot my i pod password so what to do?
#8 is great
I have a Ipod nano and i forgot my 4 digit password how do i fix this problem
Yes all you guys have to do is plug it in and go to itune and then then click on the ipod icon shows up on screen then click on restore everything will be gone including videos music and the passcode photos all of them.....
When i wanted a passcode on my ipod touch i forgot it]
from joseph
The BEST THING (i used this because this used 2 be m sis ipod, and the ipod did not sync wid this computer,and i didnt download itunes) is solution 8!!!
Lsten to da best solution al the way at da top by noggin
I cant unlock my ipod nano but everytime i search it gives me what i dont want
Well i was having fun with my ipod and.i accidently hit the lock button and i dont have a comdination well there it is
Connect to the computer and on the sync screen click restore this will reset all your settings and songs so make sure you got all your songs from that source
All u have to do is plug in ur ipod nano to ur computer get itunes opened and then itunes will automatically unlock ur ipod. trust me it works. :)
All I did was restore my ipod to the original settings
Get a new ipod
Pls send password 8gb apple ipod
I dont know who locked my ipod ......and now i a not able to open the lock code ........what can i do..????
SOURCE: How do I Unlock Ipod screen if I forgot the 4 digit password?
When connect ipod to computer, go to my computer. Click on ipod:-
-click on tools, go to folder options
-go to view tab
-check show hidden files
-a ghost like folder will apear: ipod control
-click on it and go to device
-there will be a locked file
-click and delete it
Your ipod is unlocked!!!!!!!!!!!!
JOHN
If you don't understand, go to this website on you tube!
The only way to get rid of the password is to do a "Factory Reset" which will delete everything on the iPod. You hook it up to the computer and then when you select the iPod in the "source" panel of iTunes, select the "Summary" tab. There should be a "Restore" button. Just follow the instructions that iTunes gives you. For more detail, Apple support has a page that has every little thing on it, but this should be enough to get you through it.
You guys need to perform restore on the pc
How to restore your iPod:
For Windows:
If its the ipod Touch that is disabled, use Ziphone.
http://www.ziphone.org/
Use the Ziphone ipod touch and iphone jailbreak GUI to put the ipod in recovery mode. Then restore it using iTunes.
my ipod is locked and i dont remember my code to unlock it
i have tried every possible i can to unlock it but no use please help
my freind gave me an ipod and he forgot the pasword and i screen locked it and i dont know the password
I recieved it as a gift from a friend accidentally locked it and now I can't unlock it.
I forgot my combination password to my ipod. Now i can't unlock it.
I turned on the ipod t listen to a song and as I pressed play, the ipod moved forward like it was going to the next track and locked.... how do I unlock this?
hey i have an ipod touch my password was 9232 but my lil brother kept messig with it so i changed the password now i have forgotten the password wat do i do?
i forgot my password what i do to unlock
I FORGOT MY PASSWORD NOW I CANT UNLOCK IT HELP!!!!
8 gb ipod nano
well i have an i pod touch that i bougth from a pawn shop but my lil brother was jealos and put any pass word in but he forgot it i tried every step but still nothing wut can i do
Hi i just recieved an Ipod nano from a friend and I locked his screen and don't know how to unlock it
I had just got an ipod from someone and i clicked on code but i thought i got to make it. But it went on the one thet they made and i do not know the person becz of ebay.
a big paddle lock on the screen
I was looking through my i pod when i came accros the word lock and i wanted to see what it did so i pressed it and now i doint know the combonation to unlock it.someone please help i havent listined to music for a month
help me locked cant unlock
my i pod is locked i got ia as a gift they put the code and music and now it got licked i need help unlocking it
one of my friends gave me the ipod she moved out of town and i never saw her again everything was working great untill i let my cousin borrow it and he locked it and i dont knoe the 4 digits password
i locked
i just forgot my password and need help and how to
i forgot the screenlock combination
i have a ipod touch and i got it from my friend but he said he forgot the password and i tryed typing passwords in and now it says ipod is disables and below it says connect to itunes and i did and it doesnt work what do i do ?
i forgot my password to my ipod and i dont have the PC that my Ipod was first synced to so i dont know what to do to get it unlocked !!!!
how can i unlock my ipod with he four digits if i forgot them but i tried to plug it in to my usb port and it told me its unable to find any drivers would any1 have any sort of idea how this problem can possibly be overcome by using another way other than entering the ipod itself
i made a screen lock for my ipod nano 4th generation on mar. 7th this year an dlast night i locked my ipod so my sis and brother can go on it but this morning i tried unlocking so i can take it to school and i forgot the combination how can i fix it?
hi i forgot my password and i dont know wat to do.
my freind forgot the password
hi my i pod is locked and do not have same computer and i forget the 4 didgets
i locked my ipod by accident and forgot the combo! what i do???
my i pod locked and i forgot the code and i dont have that same computer network as i did when i put songs and stuff what do i do
i have locked the screen but forgoten 4 digit lock code
i locked my ipod and i forgot the password
i got a ipod nano (3 generation) from a friend and i dont know the combination neither does she? i need to know the combination please help me
i nedd to unlock my ipod nano
i dun remember my 4 digit password.... > <
I recently recived an Ipod from my birthday adn I do not know the 4 digit password I am leaving for a long long drive soon and I need to unlock it can someone help me please!!!!!!!!!!!!!!!!!!!
i got a ipod and i hit the screen lock but i can't unlock it because i never made a lock comination.
i have problem to my ipod how yo unlock my screen lock??
i locked my screen and forgot my code also i bought it at the pawn shop so the computer i use is not the one it was first used on its ipod nano 3rd gen
i don't know my i pod code is there a way i can unlock it?
i was going through my ipod and i clicked on settings and lock and now i cant get in my ipod.help
i cant unlock my code!!!!!!!!!!
my ipod is 8gb and i can't unlock it because i forgot the 4-digits
same problem
my ipod is a 4GB ipod and i have forgotten the 4 digit code From steph
my bestfriend was over one day, and she was listening to my i-POD nano, she gave it back and it said enter code. its a four digit number, and i don't know it. help me !!
alright, so i locked my screen on my iPod nano, and i forgot to write down the combination so i can unlock it. i can't unlock it! what do i do?
my brother invented a four diget code that he forgot and so i couldnt unlock my ipod what do i do ?
ipod 30 gb
my daughter has the same problem she made a 4 digit code and now she cannot remember her code what can she do?
i saw this video from metacafe.... all u need to do is connect your ipod to the computer then go to mycomputer and open the drive for ipod(e.g. My Ipod(E:))
after that you should view all hidden files.. you can do this by changing it from the folder options that can be found on the tools menu... you will then see a translucent folder named ipod_control open this and go to device... rename the file _locked to _unlocked... disconnect and its done!!!!
the screen of my ipod only shows do not disconnect and my computer doesnt recognize it
How do I Unlock Ipod screen if I forgot the 4 digit password? problem, and notify you when a new solution is offered.
what do i do if i locked my i pod and it comes up to the 4 digit combination sreen but i forgot my password
i lost the code for my ipod
I TRYED 2 PUT IN MY BIRTHDAY,MY LAST DIGITS OF MY PHONE NUMBERS
forgot password too
I foregot my password
i need help fats!!! my bro messed with my volume limit on my ipod and now i dont know what it is!! how do i unlock it!!!!!!!
i've created a password to lock my ipod nano , and now , i've forgotten it and i can't unlock it . what should i do ?
i forgot my screen lock password what do i do? please Help...!
SAME PROBLEM
forgot the code on my ipod help please
how can i unlock my ipod touck
my brother channged the screen lock and forgot it
my little sister happend to be messing with my ipod and some how she manged to change the password how do i figure t out?
i forgot my password and it stoped me from tryin and told me to connect it to iTunes
i have a ipod nano and i forgot my combination to my volume limit and i want to know how can i reset it
my kids locked my ipod by exident and i dont no the code
my i pod froze and i reseted it and it asked for a passcode and it doesnt work now
I forgot my for digit password code ...
my ipod is lock and i cant unlock it please help.............
hey i tried to fix my ipod by pressing two to three buttons at the same time and its not working! Please help me! I paid a lot of money for this thing!!
cant remember password to dell inspiron 2400 turn on screen states not authorize cant go any futher it is locked
a friend locked my ipod screen and forget the code.
i have tried multiples of times different combonations... but i have seemed to of forgot it. i was pretty positive i knew it , but it didnt work. HELP ME!
My 2nd generation 2 gb ipod nano has the volume locked and (i bought it used) i can't hardly hear the music... How do i unlock the volume on it? Is there a master code or something? PLZ HELP IVE TRYED EVERYTHING!!! :'(
ts locked
i have the same problem.. i forget the four digits to unlock my ipod's sreen.Please help!!!
effectuez une
what do i do if the ipod is lock and i forgot the 4 number in the password
i locked my ipod and i forgot the combonation
I Couldn't Unlock My Volume Limit To Get A Normal sound
The first of all I got into the screen lock and then I pressed ok it showed me the four boxes of 4 digit password, then I pressed ok again, it locked. I can't open the password. Please help me out!
how
forgot 4 digit password
yeah i have the same problem like the above comment
what is the code
I have my friends ipod and she has a screen lock but I dont know how to fix it!
i was messing with my ipod and i thought i knew my code and i went into screen lock and put in the code but i didnt know my 4 digit code help !!!!!!!!!!!!!!!!!! i have 3gen nano 8gb
my little brother changed my password and i dont know how to reset it how do u get ur password
i jst got a ipod touch from my friend....and i locked it and i asked him the password and he had forgotten
i jst got a new ipod for my birthday and i lost all the software and my computer crashed and i forgot my 4 digit password wat do i do???
i have one tow
I forgot my password and Now I can't get the ******* thing to work so you apple dumb asses fix it
i got a ipod touch and it locked by its slef but i dont have a code. what should i do?
got the promblem wit a 4 diget gice me a number slove the promblen meet me for $100 cash
i was listening to music and all of hell my ipod wont unlock i read the manual it didnt say **** please helpppppppppp
!!!!! 15.000$ who every fixs it oh yeah cash
help! i need a solution.....i have forgoten my password for my ipod touch....and now it keeps going disabled for like an hour and i don't know what to do!! please help and respond to my question! it is a four digit number!! please help!!!
My friend and I were messing with my Ipod when we locked it and we do not know the combination. I have tried just about everything but nothing works. How can I fix the problem?
someone at my school asked to borrow my ipod...so i said ok i guess they put a password on it and ran the battery completly dead so that i wouldn't know that they did that..and i don't know what to do HELP!!!!!!!!!!
i got a ipod nano for christmas and i locked it some how but i didn't set a password so can some one please help .
I let my sister borrow my I-Pod and she locked it HELP!!!!
i had iock my screen and now i forgot my password
i forgot my pasword
forgot the password for my I-pod and accidently locked it
i forget my 4 digits combination
my has locked the screen so can you help me with the cods to unlock .The name of ipod is apple it's 8GB
i put a password because my sister was looking at my text message so i put a password and i forgot it
i changed the password 4 digit code to unlock the screen and now neighter code will work to unlock my screen.
