Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide,
that gives step by step information on Dis-Assembling with screenshots,
even a novice can fix the disc eject problem with the help of this DIY
Guide. It also gives information on fixing many Wii Related Problems,
so its a kind of Wii Problems Reference Fix Guide.
If you have tried more than one Wii game and none will read, This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Normal
0
false
false
false
font-size:10.0pt;
The most common reason for the Wii not reading
discs is a bad drive. The following website sells the drives and does installs:
store.richsxparts.com
going again!
Sounds like the DVD drive inside of your Wii may have failed.
Sounds like something is stuck inside of your Wii's DVD Drive... someone may have stuck something in the slot? Coins? credit card? paper? Etc... sounds like this is preventing the disc from being read properly. Either this, or something inside of the drive has become broken.
The following website sells the DVD drive mechanisms and does repairs on the Wii as well:
I think if you drop the Wii, the disc ejecter breaks or something. Then you can't eject the disc or vice versa because the ejecter is broken. Call Nintendo Customer Service (1-800-255-3700 in the USA or Canada) and try to get it repaired.
you have three choices, 1. send it to get disc out, 2. take apart yourself or 3. keep pressing eject button till comes out, ( try laying it flat, on side and upside down). http://www.wii-ftw.com/?page=disassembling_wii
cannot eject the disc inside and cannot read d disc
