Please send the reset factory settings code of My Cell 1600, type RH-64 IMEI No is 352260/01/903867/2, My Mobile is No : 9880546947
You can format your Nokia 1600 device by typing:
* + 3 + call + Power on.
Before the device is reset, you need to provide
the lock code. The default lock code is 12345.
If it is not working try this code
*#7370# in standby mode.
I forgot my nokia 1600 security code..........
type:rh-64
code0525393
imei:358992/01/342699/0
CE434
356445017802973
Imi code. 359375008039261 code 0525320 please send me unlock code
When a sim insert my nokia 1600.then automaticaly the mobile on off on off mode non stop running....pls help me
Nokia 1600 restore factory
settings code 359378006852088
Good Morning:
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Testimonial: "Thank you very much for your prompt solution: 5-digit default code fitted. Have a nice day! Al"
SOURCE: I lost my security code for my nokia 1600 rh 64
hello
1_ can you save your formation in other phone .
2_that code format your phone for Nokia only
3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345
4_ other numbers *#7370# and the security n ......
and look if the problem is solve it
because after this . you have like a new mobile
SOURCE: i forgot my security code
You may kindly note that the default security code for all Nokia handsets is 12345. In the event the security code is changed and you are unable to recall it, then the phone needs to be reset. You may kindly note that the security code can be reset at any Nokia Care Centre. Kindly be aware that there will be a service provision fee associated with this service, as it is a non-warranty procedure.
You may kindly note, once the phone has been reset, all data in the mobile will be lost. I recommend you take along the proof of purchase/receipt while visiting the Nokia Care.
Good Luck.
Thanks for using FixYa.
SOURCE: I have forgotten my security code of Nokia 1600 want to reset it
I am forget my nokia 1600 security. How can i unlock my phone?
Please send the reset factory settings code of My Cell 1600, type RH-64 IMEI No is 356957011369320, My Mobile is No : 9088162227
7517511631
I hot help yoo
I gave reset my phone Nokia
1600 .then what will its reset code
