SOURCE: find charger for world tech rc helicopter skyhawk
good day,
hope this link below will help tp solve your problem.
toys
SOURCE: My air hogs sharpshooter is
Did you turn the actual helicopter OFF? make sure that is switched OFF. Did that help?
SOURCE: My helicopter won't take off,
This issue is the "Drive Gear Unit" It is the small gear just above the motors which is attached to the very large gear. You will have seen several posts indicating that sometimes this gear shifts and does not engage the larger gear. In my case I looked and say that it was indeed trying to engage the larger gear, however the gear is stripped (the teeth are nearly gone). The sound that you are hearing is the sound of the gear slipping against the Bigger gear. I have a UJ365 which is a newer model. To my disappointment I cannot find a "Drive Gear Unit" anywhere on line. The copter will not function without it. This issue is that it takes the lift of both rotors to lift the copter into the air. There are two motors (one for each rotor) and each motor has one of these drive gear units. Each of these attach to the larger gears which turn the rotors. The rotors each turn in the opposite direction. This is what keeps the copter from continually turning in one direction. When one of the "main Gear Units" becomes damaged it seems to have three noticeable effects. (1) There is a noise that is the gear grinding against the bigger gear. (2) Because many of the teeth are stripped the drive gear engages the bigger bear only some of the time, this causes the rotor to turn slower and in-turn causes there not to be enough lift from the rotors to lift the copter. And finally (3), someone noted that copter wants to spin in one direction. Understanding the above, you can now understand that if one of the rotors is not reaching its full potential to turn, it is also not reaching its full potential to counter act the other fully functioning rotor. Thus the fully functioning rotor is forcing the copter to spin in its direction and the malfunctioning rotor is not spinning fast enough to stop the spin.
So this is the answer to your questions, hopefully on the older models there will be parts available for you to replace it. The copter cannot work until the part is replaced.
SOURCE: Air hogs pocket copter, brand
You bought a defective mini copter, the internal micro relay is malfunctioning and I hope you could bring it back where you bought it. Replace it with a new one and let them try to test flight it before you go home.
Hope that helps you out.
Thanks for asking FixYa!
Testimonial: "I wondered if that was the problem. Well, the part about there being a defect. I had no idea about the relay whosamajiggit! I hope I can exchange it."
SOURCE: my green air hog helicopter
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
