Microsoft Xbox 360 Halo 3 Special Edition Console Logo
Posted on Dec 23, 2012
GAMES GOT STUCK IN THE XBOX 360 HALO EDITION THE 3RD TIME i USED IT
I got the limited edition Halo edition last year for Christmas and used it 2 times. The 3rd time I went to use it the game got stuck. I tried to remove the game from the tray and now the tray is loose and wont close:(
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Dec 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
1543
Points
26
It needs a new drive chassis, you will have broken the little plastic tabs that hold the tray level and straight! you can replace the drive but the new drive will need either the old logic board off the broken drive fitted to the new drive or the dvd key dumped off the old drive and flashed to the new one to make it work.
4 Related Answers
Anonymous
  • Posted on Jan 03, 2008
SOURCE: xbox 360 halo edition
the laser is burning your discs and you need to take it back, seems to be a common fault with the 360, i am onto my 3rd console. hope this helps
Anonymous
  • 26 Answers
  • Posted on Jul 13, 2009
SOURCE: it wont read 360 games but it reads original Xbox games
cd drive error, if its an older xbox thats what it would be, either that or disk read error thing, i would suggest taking it in somewhere and have people look at it. or check the xox 360 games to see if there are any big scratches. that would be a big problem if there r scratches.
Anonymous
  • 37 Answers
  • Posted on Sep 20, 2009
SOURCE: my xbox 360 won't read my halo 3 legendary edition game disc
The disc is bad try returnig it or run it thrue a cd cleaner i use memorex from wal-mart it works very good
Anonymous
  • 43 Answers
  • Posted on Jul 06, 2010
SOURCE: Xbox 360
i counter that with jfci paeusfrk]Q@# VPYZSAEF kfhdj gsd g.f4dg5a41d 1g +z+ 4sf 4cf 45A F98 451 PINGUS
My disk drive don't read games that aren't scratch how can i replace the disk drive on my xbox 360 halo 3 edition
Unfortunately, replacing your disk drive is not something that a normal user can do. You will need to call Microsoft support at (800) 469-9269 and see if they can fix it for you.
Wont turn on its likes its out of batteries but i cant open it to get into it xbox 360 halo 3 limited edition wireless mic
Hi, you don't need to open it. There must be a charge cable in the box, just plug it to the headset then to Xbox and let it recharge for few hours. Regards Peter
2answers
My sons have a limited edition halo green xbox but it wont read discs just says open tray.I then bought one of a friend and thats not working i plug it into the tv but it comes up no signal.I have 2 bored...
Fastest way would be install drive from no signal xbox to the halo edition
reg xbox drives are swappable
there are about 6 torx screws on bottom and 1 on the hdd tray 2 on drive holder not a very difficult fix
Xbox 360
1helpful
My xbox 360 wont read halo 3 but reads my other games?
Your disk may be damaged. If it has scratches on it that can cause major problems. But the worst problems are caused by fingerprints. Fingerprints prevent the laser from reading the data on the disk. If your disk has fingerprints, run it under the water faucett and, using a soft cloth (the kind you would clean eyeglasses with), wipe from the center to the outside of the disk, not in a circle. If the problem persists, the Halo 3 data on your hard drive may be corrupted. Delete the data and try starting the game then.
My xbox 360 won't read my halo 3 legendary edition game disc
Halo Special edition xbox console: Error E74 after update
the odds are very good... The error is caused when there's a problem with video, either because the A/V cable used is broken, or what's even worse, when Ana, the Xbox 360 hardware scaler chip is damaged. Also try this take the AV cable, plug it out and plug it in, if it still doesn't work unplug it, wipe the metal part with a soft cloth then plug it in. That might help.But i bet you will end up sending it off again.
Xbox 360 halo edition
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
