Pride Mobility Pride Pursuit XL 4 Wheel PMV Electric Mobility Scooter Logo
Anonymous Posted on Dec 19, 2012
Pride Pursuit XL scooter won't charge
I was caught in a brief shower yesterday and when I got home and tried to charger the batteries, the charger just shut off. I tried using a different charger and the same thing happened. I didn't think the scooter got that wet! This is a new scooter! The scooter didn't act differently while I was still out, after the rain. Everything appears to be working fine... except the charging mechanism. :( Does anybody have any idea what might be wrong?
Rob Hill
Level 3:
  • Pride Mobility Master 1,480 Answers
  • Posted on Dec 20, 2012
Rob Hill
Level 3:
Answers
1480
Questions
0
Helped
518208
Points
3838
Is this the Pride Colt XL 8 scooter ? if so look at the steering column, there is a fuse here for the charger ?
Please give feedback.
Why is my pride pursuit scooter dead... no lights anything
Sounds like the water has damaged the controller or the wiring.
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
FAULT CODE SAYS BATTS ARE LOW AFTER CHARGING
hi, lets work on the assumption that your scooter is correct in saying the batteries are low, why is that ? , well you need to look at the charger and if possible try another charger , the other thing that could have happened is the charger fuse has blown, this is located on the tiller stem
If you are convinced that the charger and fuse are okay , look at the batteries, just because it a new scooter does not mean it new batteries ., let me explain let say your scooter has been assembled a year ago, batteries fitted , now the batteries have not been touched during that period , that in itself can kill batteries or as soon as you start charging them they give up.
I have seen this happen on many occasions.
Please rate my assistance
Regards
Blue light on battery condition meter is blinking. It doesn't stop.
hi the blue light is indicating a fault, now count the flashes before a pause, or does it just flash all of the time ?
Please keep me updated.
Regards
1helpful
Scooter won't take a charge
scooter battries must be charged on a regular basis.or else the on board charger wont charge them .Try useing a trickle charger to bring them back to life. if you dont have access to one bring them to a local service station they should charge them for a small fee.
Wont go
HI,
I AM A PRIDE MOBILITYREPAIR TECH.
SEVERAL THINGS CAN BE THE PROBLEM:
1. BATTERY CHARGER CAN BE BAD
2. THROTTLE POT OR SPEED POT CAN BE BAD
3.IF THE FREE WHEEL LEVER IS NOT ENGAGED THE SCOOTER WON'T RUN
4. IF THE CHARGER CORD IS PLUGGED IN IT WON'T RUN
5. FINALLY IF ALL THOSE ITEMS ARE OK YOU HAVE A CONTROLLER PROBLEM, WHICH IS THE MOST LIKLEY PROBLEM...THATS COSTLY
6. YOU COULD ALSO HAVE A BATTERY PROBLEM, GET THEM LOAD TESTED.
YOU CAN GET HELP BY LOGGING ON TO GOLDEN TECHNOLOGIES.COM AND ENTERING YOUR AREA CODE TO GET LOCAL PROVIDERS TO HELP YOU. OR CALLING 1-800-624-6374
GOOD LUCK
TIM
1helpful
2answers
Scooter is running slow
Have the batteries tested with a load tester. Usually when it starts to move slow it means the batteries are going.
Top Pride Mobility Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Pride Mobility Health and Beauty Expert? Answer questions, earn points and help others
