SOURCE: memory card
connect the card in memory card reader and got to mycomputer-->right click-->manage-->disk management. see weather you memory size is correct or not if its different right click the memory card and delete the partation then create a new partation
i was done this to my san disk memory card
SOURCE: memory card micro sd cannot format
Definitely your Micro SD Card has a problem. might be ita a virus problem.
Try to format it by your Computer not by your Phone. If you have a AntiVirus scan your Card and then try to format it.
if you are not successful in one chance Don't afraid at all, try it three or four times by removing and then inserting the Card again in the Computer........
SOURCE: vaio and micro sd
Appreciate the direct "Ask Me".
Since you have verified that the card works (in your phone) and that the adapter works (in another computer), then the issue could very well be with the Sony VAIO VGN-C140G/B. More specifically, the USB ports/drivers. Presumably that the Sandisk 2Gb Micro SD & the adapter were working before and that you are using Windows Vista, pls check your updates that has anything to do with USB. Alternately, you may want to rollback/downgrade the USB drivers and/or seek USB driver update from the Sony site rather from Microsoft.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for your continued patronage of FixYa.
I have also formated the disk using the Gopro. No change!
