20 Most Recent GoPro HD Hero 3: Black Edition Camera Questions & Answers
Why is choppy playback on my mac?
Try a new sd card class 10 sdhs high mb/s rate helps. Need a night vision or flat lens for your gopro contour or drift hd cameras? RageCams Will Price Match & offer better custom tailored installation kits with their lenses to fill the gaps & hold focus which is very important. We offer more HQ lenses / replacement parts & have serviced more gopro cameras than anyone on the net & at the highest quality service available. Scratched your gopro lens or damage your led readout screen? We can replace it for you quickly or offer you the parts to do it yourself. HD Wearable Video Custom Mods By RageCams HD Wearable Video Custom Mods By RageCams
8/26/2014 5:57:53 PM • GoPro HD Hero 3:... • Answered on Aug 26, 2014
Gopro hero3+ scratched broken lens
hi, here you have it: http://provideocoalition.com/jfoster/story/gopro-replacement-lenses-for-hero3-3
8/26/2014 5:47:07 PM • GoPro HD Hero 3:... • Answered on Aug 26, 2014
Hello I have a problem with my gopro 3 black
try some rubbing alcohol and a q tip around the button and keep pressing until you have movement. hope it works for ya.
7/14/2014 8:48:34 AM • GoPro HD Hero 3:... • Answered on Jul 14, 2014
I only get a black screen with a green line through video?
hi, through wich port? hdmi or usb? if from usb, what cable are you using ? self made or bought one, and then, wich one, the video alone, the fpv alone, the fpv+power, the combo cable ???
3/20/2014 6:50:25 AM • GoPro HD Hero 3:... • Answered on Mar 20, 2014
Vidieo not working ,lagging you always have a
hi, is your computer strong enought to play full hd ? is your sd card hdxc minimum ? looks like you have problem of flow, so, sd hdxc minimum to be sure not to loose frames, and a core 2 duo 2.4ghz minimum with a good grafic card to be able to read fluid videos in full hd
3/20/2014 6:44:35 AM • GoPro HD Hero 3:... • Answered on Mar 20, 2014
Wiil not play on tv or computer
pull the sd card out and use an adapter, then plug the card in to the pc reader.
10/18/2013 10:14:28 PM • GoPro HD Hero 3:... • Answered on Oct 18, 2013
How do you get an LG LV720 video cassette recorder out of safe mode?
To get your LG LV720 video cassette recorder out of safe mode, you can follow these steps: Locate the original remote control that came with your VCR. Look for a button marked as C.LOCK or LOCK. Press this button. This should allow you to exit the safe mode3. If you don't have the original remote, you might face some difficulties. Some users have reported success by pressing the record button for 6 seconds on their Panasonic VCRs but it's unclear if this will work for an LG model.
4/21/2024 3:09:22 PM • Video Cameras • Answered 2 days ago
Movavi video editor 11
Hi, which type of system you use ? if your computer is not equipped with the requirement, this will not work properly,
3/17/2024 9:39:09 PM • Video Cameras • Answered on Mar 17, 2024
How to factory reset model sdr-b853009?
All question need 'make model (what it is) as first 3 words please. https://www.google.com/search?q=sdr-b853009+reset All answers can be found on Google. ..
3/12/2024 4:40:20 AM • Video Cameras • Answered on Mar 12, 2024
My foxelli trail camera is only doing black pictures at night?
I would check the IR lamps work on the front of the camera.
3/11/2024 7:23:24 PM • Video Cameras • Answered on Mar 11, 2024
What is error code EO1
Depends on what type of camera but this site may help you. https://www.instructables.com/Fix-JVC-GR-DV800U-Camcorder-Error-Messages-E01-E02/
3/11/2024 3:50:38 PM • Video Cameras • Answered on Mar 11, 2024
2answers
I am looking for an Instruction manual for Zennox 4000 camcorder please
https://files.canon-europe.com/files/soft29721/Manual/MV550i_530i_En.pdf
2/21/2024 2:12:51 AM • Video Cameras • Answered on Feb 21, 2024
Wilderness Innovations trail cam model number K8B37D. Owner's Manual please?
That particular model doesn't seem to be listed anywhere. Contact the maker direct. https://www.google.com/search?q=Wilderness+Innovations+trail+cam+K8B37D+manual ..
2/5/2024 8:50:23 PM • Video Cameras • Answered on Feb 05, 2024
Rca vhs camcorder cpr300 won't playback or record
This may be bad belts, and what you should check for is the belts on the side of the tape deck toward the lens and pickup(front), and the drive belt in the middle. All the belts are under the circuit board, so you need to remove that to get at them, and then you can replace them with rubber bands of same or slightly smaller size. Use a screwdriver to help get the old belts off, and put new ones on. (In the tight space) Then check if the tape deck opens and closes, and see if the tape moves when you hit play/record. If you put in a tape you know has a video written onto it, then put that in, and try to play it. If you get a noisy or staticky picture, then try wiping the video head drum(Big shiny cylinder that spins, with the small slits in the side.) with some alchohol and a glasses cleaning cloth or paper. Also, wipe the audio/control head, the silver box that the tape runs across just before it goes by the black roller. Also, check for gunk or obstructions that have gotten in the mechanism of the tape deck in the back. Make sure the video drum is spinning, and that the tape is pulled out of the cassette by some small rollers and wrapped around the video drum DURING playback/record. I say 'during' because some camcorders will retract the tape back to the cassette for fast forward and fast rewind. I hope you get your camcorder to work! Thanks! 73 Sincerely, Beauregard42. (<-- My YT channel where I have some tech stuff)
1/9/2024 12:49:45 AM • Video Cameras • Answered on Jan 09, 2024
2answers
Error occurred please turn unit off then turn on again
Then what happened ?
1/2/2024 9:13:47 AM • Video Cameras • Answered on Jan 02, 2024
2answers
Silicon Valley Products SVP HDDV 2600 video camera. How to download drivers for it please?
There is no software online, it was a 'one hit wonder' and it says the disc that came with it only contained drivers and Ulead Video Studio 7, Ulead Photo Express 5. Fairly typical on such devices. Everything for $100 including the disc. https://www.ebay.ca/itm/275425639098 https://www.manualslib.com/manual/315830/Svp-Hddv-2100.html Driver Guide says it has them. Or you can connect the the camera to the computer, turn it on, then go to Device Manage in Settings and you will see a device with a banged out triangle icon,. Right click and click Find Driver. Microsoft should have one that works. https://www.google.com/search?q=svp+hddv+2600+video+camera+drivers+download ..
12/30/2023 3:11:37 AM • Video Cameras • Answered on Dec 30, 2023
GoPro HD Hero 3: Black Edition Camera Logo
23 questions posted
Top GoPro Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a GoPro Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GoPro Video Cameras
  • GoPro Video Cameras
Most Popular Question
choppy playback mac
  • Video Cameras
