SOURCE: certificate error contact application supplier error msg
Send me the theme File i can get it signed for u.or visit this link http://www.mobilesmania.com/forum/index.php?&showtopic=49264 u will get an idea on how to sign files.
SOURCE: nokia 6120 is not sending sms it gives msg
Try going into message settings found in your messages. Then go into text messages and look for the command: "Reply via same centre" activate this to yes then try again.
SOURCE: My E71 can't send SMS but it can RECEIVE text
Try the following steps. I fixed the same problem on my E71 with these.
1. move the sms which can not be sent into the draft box.
2. switch the phone to offline mode.
3. enter draft box, and send the sms
4. after the notification of "saving into sending box..", power off the phone.
5. turn on the phone again, select "no" for the question, then, wait several second, u can see the sms is sent.
SOURCE: i cannot send a sms
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
