20 Most Recent
Nokia E5-00.2 Carbon Black Questions & Answers
My Nokia 301 is saying operation failed every time I try to listen to a song
Here are some steps you can try to resolve this issue:
Update your phone's software: Make sure your Nokia 301 is running the latest software version. You can check for updates by going to Menu > Settings > Phone > Device Updates .
Reset your phone: A hard reset may help resolve the issue. Before doing so, make sure to back up all your data as this will erase all data on your phone. To perform a hard reset, go to Menu > Settings > Restore Factory Settings .
Check the file format of the music files: Ensure that the music files you transferred from your smartphone are in a compatible format such as MP3, AAC, or WMA .
Try a different music player app: If the above steps do not work, try using a different music player app such as VLC or Winamp .
Unlock code for nokia x2-01
If you need Unlock code for NOKIA X2-01 you can contact the service provider.They will give unlock code and instructions using that you can unlock your NOKIA X2-01..But they will ask you to wait for some days or even some months.If you need unlock code immediately,visit the site
Prounlocking.com get unlock code at reasonable cost and unlock it easily and very soon.
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
