It seems that the pto shaft is too short to work properly on this tractor.
Susan Ensley supplies a great answer for this 2012 question!
I had that same problem with mine. What you have to do is to buy a longer shaft and cut it to the size that will work. Mine CAME too long for that purpose; cut it to fit my smaller Kubota. Traded that tractor in for a much larger one and had to repeat the process, only THIS one worked fine with the long length. I hope this makes sense! My female brain only knows how to explain it as I did! But, mine works now!
SOURCE: 4' king kutter makes grinding noise at times
USE SAY A BROOM STICK AND ON THE OUTSIDE ON THE DECK YOU CAN USE IT LIKE A STETHOSCOPE AND PUT IT TO YOUR EAR AND LISTEN TO DIFFERENT SPOTS ON THE DECK TO HELP YOU ZERO IN ON THE CULPRIT .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
