Dell Inspiron dndon023 Notebook Logo
madi Posted on Dec 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I acidently turned the touchpad to my insprion17 off in the settings, now despite me pressing F3 the touchpad won't turn on. What do I do?/How do I turn the touchpad back on?
An orange light is on the keyboard
max carson
Level 3:
  • Dell Master 7,627 Answers
  • Posted on Dec 05, 2012
max carson
Dell Master
Level 3:
Answers
7627
Questions
Helped
1015309
Points
21773
De-activat touchpad Inspirin N5110
Fn + F3 Press and hold the < Fn >
key, then press the < F3 > key.
Press the < F6 > key. i_keyboard_generic_touchpad_disable_key_bd_v1.jpg Press the Touchpad Disable/Enable key,
(the key is located to the right of the < F12 > key)
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
Sep 28, 2012 • Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
1helpful
2answers
My cursor won't move
Press F3 It should have a keypad emblem with an x across it.
4helpful
3answers
How do i turn off zoom function of synaptics touch pad Hp laptop
Are you talking about the two finger zoom by spreading your fingers apart on the touchpad to zoom out or pinching them together to zoom back in?
This works for Dell touch pads so below where it says ‘Dell touchpad’ it probably says HP touchpad?
· Goto your control panel
· Click on ‘Mouse’
· Click on the ‘Dell touchpad’ tab
· On the resultant popup screen, double click on the main touch pad region
· Click on the ‘gestures’ setting
· Uncheck the zoom
Good luck…Chris
I have a asus Eee pc904hd and the touch pad is turned off the cursure is locked i have pressed the fn f3 but no luck
Check in control panel.
GO to start menu->control panel.
Then find touchpad utility and enable touchpad if it is disable.
If still it not works then reinstall touchpad driver.
Let me know if you need further assistance.
Thanks.
16helpful
2answers
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
