TDK DA-5700 CD Player Logo
Posted on Jan 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Converting Audio Cassettes to CDs
I cannot get my TDK DA-5700 to make CDs from audio tapes. I am a non-technical person and have no idea what it means when it asks me if I want co-axial or manual. I also don't understand when it asks about increment level. I've tried evry combination, but nothing works. Can anyone guide me through the process?
Anonymous
Level 2:
Scholar:
  • Expert 75 Answers
  • Posted on Mar 26, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
75
Questions
Helped
29985
Points
188
First off I assume you have the manual for you're 5700. if not a PDF copy is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027911.pdf
Assuming you have a standalone tape deck that has phono inputs and outputs connection and recording recording should be easily achieved.
Forget the coaxial unless of course your tape deck has digital outputs.
Assuming it hasn't just connect the two output sockets from the tape dec which may be labelled REC out left and REC out right to the Line in (L) and Line (R) of the CD recorder.
The physical setup is now complete.
The increment level they refer to in the manual offers you a choice of 3 final decibel output levels in other words how loud it will be when it is finally recorded onto the disc.
the last paragraph on page 16 is relevant to the setup described above.
Page 15 of your manual is all you need to achieve tape transfer to CD.
follow the steps below and choose ANALOG the source to be played is your tape deck so once the process has begun press the play button on your tape deck and you should get a decent recording. Leave everything else at their default settings until you get a better understanding of how to tweak your recordings.
Personally I transfer audio tapes directly to my PC and Audio edit them until they are perfect but I've been doing this for years.
Good luck
here's a snippet
To record from an external source:
1. Turn power ON.
2. Place a recordable audio disc (CD-R or CD-RW) label side up
in TRAY II.
3. Close TRAY II. (When a blank disc is placed in TRAY II, the display
will show BLANK.)
4. Press INPUT until the source you want to record is selected.
DIGITAL OPTICAL:
record a source connected to the DIGITAL IN (OPTICAL) terminal.
DIGITAL COAXIAL:
record a source connected to the DIGITAL IN (COAXIAL) terminal.
ANALOG:
record a source connected to the analog LINE IN jacks.
5. Select the desired mode of track division (track number
assignment) by pressing the MANUAL/AUTO button (see the
ADVANCED RECORDING section for more information).
6. Press the RECORD button.
The unit enters record pause mode.
The PAUSE [ ] icon and REC blink on the display.
7. Press the PLAY (ENTER) [ ] button of TRAY II to start recording.
8. Play the source to be recorded.
• During digital recording, if the input signal stops for 5 seconds,
recording will stop.
• During analog recording, if the input signal stops for 20 seconds,
• If the unit detects copy-prohibit signals during recording,
CAN’T COPY appears on the display and recording is stopped.
To stop recording: Press the STOP [] button
To temporarily pause recording: Press the PAUSE [ ] button.
Remember that every time recording is paused or stopped,
a new track number will be assigned.
@want to record from my reel to reel tape,to cd's on tdk da5700
Soooo, connect its output to the Line In and boogie.
1helpful
Owners Manual
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
How to record from the turntable using the TDK DA 5900
you need to run your rca cables from your amp/mixer depending on what your using,from the outputs into the inputs on cd recorder.
trhen make sure youve got the right cds cause i own a sony cd recorder an can only use sony digital audio cds,so you want to check that.
there should be a record button on unit press it and then play and you should be away.good luck any problems ask
Need tdk da 5700 user manual
http://www.fixya.com/search/p204708-tdk_da_5700_cd_player/manual
Lost Remote - TDK DA-5700
Try EBAY or CRAIGSLIST and search for remote "model number"
Converting old audio cassettes into MP3 files
You need a tape deck with line out jacks. Hook up line out jacks to line in jack on your computer. You'll need appropriate software to do the conversion - for example Audacity - it's free.
Recording with tdk da-3826
Data cds will not work with this recorder.
You must use music or digital audio cd's when recording!
3answers
No audio
Select the analogue source input.
Lost the manual, can't get hooked up
You need to use an audio CDr, data or computer CDr's will not work in this machine. I don't know this specific machine, but usually you select the input, then 'rec type' eg manual,1 track or 1 disc,then press record to get into record pause,start your source,then press play on the unit to start recording. To finalize, you press finalize then either the play or rec button to start the finalize process.
Top TDK Audio Players & Recorders Experts
August Brown
August Brown
Trond Baarli Olsen
Trond Baarli Olsen
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
