20 Most Recent TDK DA-5700 CD Player Questions & Answers
Soooo, connect its output to the Line In and boogie.
TDK DA-5700 CD... | Answered on Jun 29, 2011
It will not record on any medium that doesn't say "Music" or "Audio" on it.
TDK DA-5700 CD... | Answered on Apr 05, 2011
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
TDK DA-5700 CD... | Answered on Jan 06, 2010
DOWNLOAD FROM TDK WEBSITE
TDK DA-5700 CD... | Answered on May 15, 2009
http://www.fixya.com/search/p204708-tdk_da_5700_cd_player/manual
TDK DA-5700 CD... | Answered on Mar 27, 2009
First off I assume you have the manual for you're 5700. if not a PDF copy is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027911.pdf
Assuming you have a standalone tape deck that has phono inputs and outputs connection and recording recording should be easily achieved.
Forget the coaxial unless of course your tape deck has digital outputs.
Assuming it hasn't just connect the two output sockets from the tape dec which may be labelled REC out left and REC out right to the Line in (L) and Line (R) of the CD recorder.
The physical setup is now complete.
The increment level they refer to in the manual offers you a choice of 3 final decibel output levels in other words how loud it will be when it is finally recorded onto the disc.
the last paragraph on page 16 is relevant to the setup described above.
Page 15 of your manual is all you need to achieve tape transfer to CD.
follow the steps below and choose ANALOG the source to be played is your tape deck so once the process has begun press the play button on your tape deck and you should get a decent recording. Leave everything else at their default settings until you get a better understanding of how to tweak your recordings.
Personally I transfer audio tapes directly to my PC and Audio edit them until they are perfect but I've been doing this for years.
Good luck
here's a snippet
To record from an external source:
1. Turn power ON.
2. Place a recordable audio disc (CD-R or CD-RW) label side up
in TRAY II.
3. Close TRAY II. (When a blank disc is placed in TRAY II, the display
will show BLANK.)
4. Press INPUT until the source you want to record is selected.
DIGITAL OPTICAL:
record a source connected to the DIGITAL IN (OPTICAL) terminal.
DIGITAL COAXIAL:
record a source connected to the DIGITAL IN (COAXIAL) terminal.
ANALOG:
record a source connected to the analog LINE IN jacks.
5. Select the desired mode of track division (track number
assignment) by pressing the MANUAL/AUTO button (see the
ADVANCED RECORDING section for more information).
6. Press the RECORD button.
The unit enters record pause mode.
The PAUSE [ ] icon and REC blink on the display.
7. Press the PLAY (ENTER) [ ] button of TRAY II to start recording.
8. Play the source to be recorded.
• During digital recording, if the input signal stops for 5 seconds,
recording will stop.
• During analog recording, if the input signal stops for 20 seconds,
• If the unit detects copy-prohibit signals during recording,
CAN’T COPY appears on the display and recording is stopped.
To stop recording: Press the STOP [] button
To temporarily pause recording: Press the PAUSE [ ] button.
Remember that every time recording is paused or stopped,
a new track number will be assigned.
TDK DA-5700 CD... | Answered on Mar 26, 2009
here you go
TDK DA-5700 CD... | Answered on Mar 25, 2009
Try EBAY or CRAIGSLIST and search for remote "model number"
TDK DA-5700 CD... | Answered on Dec 27, 2008
Google (tdk)(TiCR100p)(manual) without parens.
TDK Audio... | Answered on Sep 06, 2019
I am very interested in this issue
TDK Audio... | Answered on Jan 06, 2019
Hold down the A33 and AUX button together for 5 seconds. The A33 should flash the volume LEDs and then reset and turn off. Let the speakers remain off for 10 seconds before turning it back on. The unit powers on in the AUX mode and you should be able to press Bluetooth and pair the unit with your device.
TDK Audio... | Answered on Jan 02, 2019
The applicable code(s) would be in a compatible remote control.
TDK Audio... | Answered on May 19, 2018
ManualsLib Makes it easy to find manuals online try this site there are many others that off free manuals just search on the model u want. this one is my first port of call
TDK Audio... | Answered on May 04, 2018
MMMmm, bummer. The earphone CABLES look rather small and vulnerable?
IF you move the CABLE NEAR the connecter do you hear any sound? How about up at the earphones themselves? If you wiggle the cable are there any sounds?
There HAS to be a 'open circuit' somewhere? Maybe the volume was set too high and the LEFT earphone happened to blow out?
And perhaps it's time to treat yourself to a NEW headset with a MUCH better and substantial connecting cable?
Anthony
TDK Audio... | Answered on Apr 17, 2018
TDK DA-5700 CD Player Logo
Popular Tags
13 questions posted
Top TDK Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
tomcattech17
tomcattech17
Bill Boyd
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • TDK Audio Players & Recorders
Most Popular Question
recorder isnt recognizing blank
  • Audio Players & Recorders
