My vehicle died while driving without warning. I let it sit for 5 min and started it right up and drove it another 5 miles home without problems. Tried to drive it again and it ran for 10-15 min before it died again. Couldn't start it right away, waited 5 min and started it right up and drove home. Now it wont start at all.
SOURCE: Car Runs and Loses Power and Quits Running
Try cleaning the fuel pump filter. Under the seat behind the driver lift the carpet and you will find a round cover with six screws remove the cover. The fuel pump is directly below unscrew the retaining round plate and remove the pump. At the base of the pump is a small filter if it is covered in black muck that's your problem. clean and replace. job takes about 10 mins good luck. please let me know how you got on!
[email protected]
SOURCE: Dies after running about 2 minutes
It's got all the symptoms of a leak in the fuel line. You may want to start backward at the tank and work your way all the way to the carb to find it but it would be surprising if it was something else. All the best.
Greg
SOURCE: 92 buick lesabre: yesterday, it would not start when it was hot.
Crank sensor. Next time it does this spray some water on it and see if it cranks. Its by the crankshaft pulley towards front of car.
SOURCE: 1999 saab 9-5 stalls without warning won't restart for 30-40 min.
Hello.i had similar problem.replaced ignition coil+cranksensor,driven it for several months now.a.ok.
SOURCE: Fuel pressure intermittently drops causing sputter and die.
check for 12v constant at your fuel pump if you are not getting that replace your relay.
if you are getting 12 volts at your fuel pump the fuel pump is possible to run tuel it gets warm then shut down to a lower rpm I would then replace the fuel pump
