The strobe on the platter of my turntables was not at 0. it kept jumping. so i decided to calibrate the pitch from the pot hole at the circuit board with a volt meter. i tried turning it clockwise and anti clockwise but it did not work. I keep getting a reading of 3k31 whereas it should be 2k70. The pot does not move when i use a screw driver. Could you please assist me as to what is wrong and what i should do?
SOURCE: calibration for a new lcd hdtv
yuo sound like you are watching analoque tv press the tv button on remote for digital
SOURCE: I am trying to calibrate the touch screen and it
Your touchscreen is defective. Please contact Panasonic official service center http://heartlandsi.com to arrange a repair. It's covered under warranty.
SOURCE: Technics 1210 mk2 motor problem
Depends on if it's a belt drive turntable or direct drive.
If a belt one, there will either be a speed adjuster on the top of the motor, or one on a PC Board. And yes apart from setting the speed, it as straightforward as taking the old one out and wiring the new one in.
The direct drive, will also have to be adjusted for speed too.
SOURCE: pitch light pulsates when i press start
the pitch adjuster is supposed to blink that is how you adjust the pitch. hope i understood your question right.
