I used a Panasonic KX-T7630 phone how can I activate my voicemail box. See I'm a third party on the phone with an another company. Not sure how to fix this. If you call the main company with my extension I have a voicemail set up but if you call the Company # is not set up.
Thanks
I have seen the same problem with some users (I look after the PABX) so I just go into the maintenance console and set up the foreward to the default voice mail number. Or you can try the following:
CALL FORWARDING HANDSET
1. Press the Speaker Phone Key on your handset
2. Then Press the FWD/DND Key
3. Then select the Forward type you desire -
Key 2 - Immediate
Key 5 - Busy/No Answer
4. Then dial the internal extension number (eg.444) or voicemail pilot (201)
4a. If forwarding to external number dial 0 then dial outside telephone number
5. Dial # then press the Speaker Phone key
Use the voice mail that is set for your system.
Hope this helps
It requires system programming. Contact your installer or whoever set up the system.
how to set up voicemail
