Looking back, over my life
I can see, how far I've come
I have had, some cloudy days
But oh the Lord has brought me, from a mighty long way
I've been up, and I've been down
But you never left me, you were always around
You stood by me, yes you did, through thick and thin
And I can truly say, that you've been my closest friend
Lord I know you've been so good to me
You've been so good
You've been so good
And I just want a thank you
I thank you
Oh I thank you Lord because you've been so good
You've been so good, so good
Let me say this right here
When I was down , I couldn't see my way
You stepped in and you made a way
That ain't all you done
When I was lost, I couldn't see the light
But Lord You stepped in, yes you did Lord, and you made my pathway bright
You've been so good
I know --you've been good to me
You've been so good
Right now Lord, I just want a thank you
I thank you
Oh I thank you Lord, Oh Lord I want a
thank you, Let me thank you I want a
thank you Lord
Yes I do Lord, Let me, thank you Let me
thank you
thank you Lord
Cause you've been so good, so good
So good
If the battery is good you will need to follow flow. Test light is the easiest to use. First hook light to ground and touch pos terminal,lights good next touch pos battery cable end, lights good. Next follow pos cable to starter pos terminal,lights good. Next hook test light to bat pos teminal,touch neg terminal,lights good. Then touch engine block, lights good ground. Next move test light clamp back to ground/neg side and touch alt pos terminal,lights good.if all that tests good, if all good move inside and check for power at ign switch pos term if at any time you dont find power you have wiring issue that needs to be addressed. Let me know what you find. Russ
by going into start> control panel > and display you can adjust the resolution of your screen here is a list of the correct sizes for the screens
Please let me know the outcome of this, if it says frequency out of range then youwill need to download the drivers for your graphics card before doing this.
14"
15"
17"
19"
21"
640x480
BEST
GOOD
TOO BIG
HUGE
TERRIBLE
800x600
GOOD
BEST
GOOD
TOO BIG
HUGE
1024x768
TOO SMALL
GOOD
BEST
GOOD
STILL GOOD
1280x1024
TINY
TOO SMALL
GOOD
BEST
GOOD
1600x1200
TERRIBLE
TINY
TOO SMALL
GOOD
BEST
most likely if you have to jump it then your battery is not good or your baterry connections arent good or ground from battery to chassis isnt good or combination of either... Good Luck
LETS SEE BATTERY GOOD! STARTER GOOD? BATTERY CABLES GOOD? CONNECTION FROM THE BATTERY GOOD! CONNECTION FROM THE STARTER TO THE BATTERY GOOD!
WIRE FROM THE STARTER TO THE IGNITION SWITCH GOOD???
IN THIS WIRE THERE IS A FUSEABLE LINK CHECK IT
IF YOU CAN SHORT THE SOLINOID OUT ON THE STARTER AND THE CAR TURNS OVER THE FUSEABLE LINK IS BAD
IF EVERYTHING IS GOOD CHECK TO SEE IF THE MOTOR IS GOOD
