My washer recently started leaving water inside when the cycle was finished. It does not do it all the time. Just last night in the middle of a cycle it stopped and it had an error code 02 F. How can I fix this?
F/02 code appears because:---------Long DrainIf the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed. -------------- to resolve this problem :---------- Press PAUSE/CANCEL twice to clear the display.
Check the drain hose and make sure it is not plugged or kinked.
Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects.
If the above does not correct the problem, replace the pump.----------------
I couldn’t find any error code 2H but I did find an error code H2O. This code means insufficient water pressure. If the display reads 2H, it usually means the start delay function is turned on. The dishwasher will turn on in 2 hours if door is closed. This dishwasher is advanced. To understand all operations you should read the user guide or manual.
Good Day, Your
washing machine is fully automatic?
the
washing cycle is normal?
if yes
do the same maybe it will help you.
for
the fully automatic washing machine mostly have drain pump, please check the
filter of your drain pump, how? remove the cup of your drain pump like a
ordinary cup, screw it clock wise or counter clock wise.
Remove
drain pump filter and clean it, some hair pins, cotton buds or coins or any
small item that coz of clog up.
if
your washing machine dont have drain pump ,but fully automatic check the drain
motor if running or not? how? open the back cover for top loader washing
machine only, select spin cycle and press start to see the drain motor running?
the drain motor is like a small box with small wire to pull the lever of the
drain to remove water inside, if the motor running or pull the lever of the
water pipe but water still inside the washing machine, remove the drain cup or
cover and clean it or check if have coin or cloth inside that coz of clog or
water stuck,
if the
drain pump or drain motor is weak this is will cause and long time draining or
totally not running the drain pump or drain motor and its cause of totally stop
the cycle of washing machine in rinse time or spin time, because all fully
automatic washing machine, after washing cycle the drain pump or drain motor
must be on, to remove water before start the next cycle. rinse or spin cycle.
Did you leave out the complete model number?, If you haven't yet check your water supply, If you changed to or have the auto stop flood hoses some washers cause them to activate.
The wires may be disconnected on the water valve(s) or a valve went bad or the main board went bad, You can use a meter to check that there is voltage going to the valve(s) when you start a fill cycle, Also some washers use a flow meter that checks water flow.
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged. 2. Check the electrical connections to the pump and ensure the pump is running. 3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
or kinked.
3. Check the electrical connections at the pump and make
2. Take of the toe panel in the front by removing the three screws.
3. Get a bunch of towels (I mean a bunch!!!)
4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
5. Clean the filter assembly.
6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
8. Remove the Torx screw that holds that is the center just under the filter screen.
9. Pull the pump forward.
10. Unclamp the pump outlet hose.
11. Remove pump
12. Unclamp the large bellow on the pumps inlet and inspect for debris.
13. Clean pump and fitler w/o getting water on the pump.
14. Install in reverse order. Remember, it is much easire to put the inlet bellow and outlet hose on the pump before you put into the washer
have you tried adjusting the feet on the front of the washer so it is tilted back slightly .This will stop the water from coming over the little lip on the front of the machine. Some dishwashers also use a little amount of water in the bottom when drying asthis helps to curculate the heat ; leave the washer to complete it's cycle and it should beep to let you know when it is finished
