My Pioneer XR-P11500C stereo will not play CD's properly. When 3 CD's are loaded, I push the play button and it will play CD #1. After CD #1 is played, the display indicates a search is in process. The search stops and "EE" is displayed. I don't hear any noise to indicate the CD tray is being rotated for the next CD. Any hints for what the problem might be? Thank you.
SOURCE: Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
SOURCE: Hooking up an Ipod to my stereo
I'm having the same problem. I pressed the "function" button about 50 times and AUX never showed up.
SOURCE: pioneer deh-6400 tuner has no audiobut cd plays ok
Did you also use an antena adapter? If not you may need one. Original in the vehicle is small and can pop out from the radio.
SOURCE: help pioneer dehp6700mp front panel stopped
you can try cleaning the contacts of the face and subpanel with qtips and rubbing alcohol or a pencil eraser. if that doesn't work, you may have a bad switch.
