Tablets & eReaders Logo
A
Anonymous Posted on Nov 12, 2012
How can I download Netflix to my Android tablet?
I have downloaded the Netflix app for Android tablets and Netflix STILL won't work on it . How can I fix this?
David Payne
Level 3:
Top Expert:
  • Proscan Master 14,162 Answers
  • Posted on Mar 19, 2016
David Payne
Proscan Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998695
Points
455836
5 Related Answers
Anonymous
  • 247 Answers
  • Posted on Jun 23, 2010
SOURCE: I got a laptop with Windows 7. Whenever I try to
find tha right driver of tablet for win7 version. Search for windows7 drivers for ur tablet try this http://www.microsoft.com/windows/compatibility/Windows-7/en-us/Details.aspx?type=Hardware&p=Wacom%20Graphire4%206X8%20Silver%20Tablet&v=Wacom&uid=CTE640S&pf=3π=8&c=Mice,%20Keyboards%20%26%20Input%20Devices&sc=Other%20Input%20Devices&os=32-bit
http://www.microsoft.com/windows/compatibility/Windows-7/en-us/Details.aspx?type=Hardware&p=Wacom%20Graphire4%204x5%20Blue%20Tablet&v=Wacom&uid=CTE440B&pf=3π=8&c=Mice,%20Keyboards%20%26%20Input%20Devices&sc=Other%20Input%20Devices&os=32-bit
Anonymous
  • Posted on Dec 31, 2010
SOURCE: Cannot access Appslib app library
I couldn't either! So, I uninstalled the appslib and reinstalled it and it works great now! You have to reset everything and you will lose apps I guess if you have any, I had none so this didn't affect me. If you go to Coby's website and under FAQ's it explains how to uninstall and install. Good luck!
Anonymous
  • 74 Answers
  • Posted on May 18, 2011
SOURCE: can i download a user manual for android tablet
http://gadget-ebook.com/ebook/android+tablet+manual+pdf
hope this helps.. please vote.. thanks
brian soufane
  • 693 Answers
  • Posted on Dec 04, 2011
SOURCE: how do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Anonymous
  • Posted on Jan 04, 2012
SOURCE: my android tablet is "frozen". Will turn on but
i tried and it did what u said it would but its still not going anywhere but to the andriod logo and donig nothing ealse
Does the zeki 10.1 tablet run Netflix
1. Connect your tablet to a wireless network.
2. Download and install the Android version of the Netflix app from the Play Store.
3. If you have a subscription to Netflix, open the app you just installed and enjoy ! Otherwise, subscribe to Netflix and then do Steps 1 and 2.
Hope this helps.
How can I see movies on netflix I have a nextbook tablet
If you have the GooglePlay app, open it and search for Netflix. Download and run the app. you willneed to supply a userid and password.
1helpful
How do i download nexflix on my Nabi 2
First, you need to download the Netflix app from
https://play.google.com/store/apps/details?id=com.netflix.mediaclient&hl=en
Next, your tablet and /or the version of Android that you have, need to actually be able to play Netflix. Unfortunately, not all tablets are capable of doing that.
4helpful
I downloaded Skype on my 4Sight 9" Android 4.0 tablet but it won't open. How can I fix it?
I've had trouble with downloaded apps not working and everytime I did I would delete the app, turn my device off then back on, and then reinstall the app.
1helpful
How can I download Netflix to my Proscan PLT 1044Android tablet?
goto www.1mobile.com, install the 1mobile app and then search and install netflix. It worked on my Proscan PLt1044 with GetJar Junk loaded on it.
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
