I purchased a Honeywell programmable PRO TH4000 thermostate to connect to a Rheem RQNJ series heat pump with back up heat coils. Neither the Honeywell operating and installation manuel nor the heat pump spec manuel gives a very good nor specific wiring for the 7 thermostat wires. The techinician where I purchase the heat pump was not much help either. (This shouldn't be this hard) I am not sure whether the back up heat coils are working properly and I had reason to believe below certain temperatures the compressor is locked out. The compressor is working at all temperatures, even at a below 20 degrees outside.
