This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Hello First thing you need to do is,inside where you can see the screen, search for the brightness and contrast options in your cameras menu. Once you know where they are go outside and try to tweak it until it works. Usually you would want a higher brightness, then just adjust the contrast until your satisfied.
you can bring more brightness by removing cover on your tv and then you will see ther 2 button ther in back of your tv one is FoCUs and other is G2 rotate the G2 button till you see more brightness on your screen put the cover back and that is if you dont know to do that go to one authorised service
How do I adjust my brightness or contrast on my laptop?
See our brightness definition for a visual example. Finally, most laptops only enable users to adjust their brightness of their screen.
Click on the above Link, Good Luck, Please dont for get to Vote.Thank you.
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
