I have a 1997 RCA TV (Model # F27676BC) which has been displaying video fine using the traditional yellow, red, and white triple cord whose inputs all look the same. I just decided to upgrade to use an S-video cable to see if the picture gets even better, but now the TV does not show anything. The stereo audio cables that are a part of this new triple cord set work fine (I can hear the DVD music) but the picture is not coming through.
I have pressed every button on the TV remote to try to find a way to adjust the input from "regular" to S-video but can't find a way to do it.
SOURCE: RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
To Make the rca type cables to work or the red white and the yellow , you have to change the INPUT from RF or TV to VIDEO. Good Luck
SOURCE: Have sound and OSD but no picture
You may have a problem with the video switching IC. Stargazer
SOURCE: RCA P46924 64" Rear Projection TV
disconnect the wii it will eventually ruin your tv game systems can't be used on rear projection because of problems caused you may need to hook everything up at the bottom of the panel and switch back and forth using your remote we had to do that on ours
SOURCE: No connection DVD to G25189TK. No external channel set. (3 or 4)
to see the dvd video you should select the AVmode using your TVremote.if the wires are not properly connected you cant see the picture or video.try to connect the wires in the front panel or the back panel.try to connect the wires as per the notes given as audio input,video input etc.
hi
you can change the external channel manualy or follow the steps mentioned here . http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=DCP750/37&scy=US&slg=AEN&grp=HOME_ENTERTAINMENT_GR&cat=AUDIO_SYSTEMS_CA&sct=SU00303_SU
if it doesnt work best to buy remote from https://secure.logmein.com/home.asp?lang=en
