first i will cover turning the unit on. then i will cover how to charge the unit. -Move the power switch on the top of the iPod Shuffle to the "Normal" or "Shuffle" position.
Press the play button on the iPod Shuffle to begin music playback. If the iPod does not begin to play, follow the rest of the instructions.
Plug the iPod USB cable into the bottom of your iPod Shuffle and then connect the other end of the cable to your iPod power adapter.
Plug the iPod power adapter into a standard electrical outlet to charge the iPod Shuffle's battery. Try to press the play button again.
Connect the iPod Shuffle to your Mac or PC computer using the iPod USB cable. Then, open the iTunes program on the computer and sync your iPod with your music library. If your iPod Shuffle was frozen, it should now turn on.
to tell if the ipod shuffle is charging. Eject iPod shuffle in iTunes, but leave it physically connected to the USB port. The front LED should be orange if it's charging (or green if it's fully charged). If it's not charging (such is the case if it's connected to a low-power USB port on a keyboard), you won't see a front LED.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
i will be glad to assist you with this. If this step doesnt help please let me know and i can instruct you on how to reset your ipod.
Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
While in disk mode, connect the iPod to iTunes and try to restore.
If the iPod is still not recognized by iTunes, the iPod should be serviced.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
utting iPods with a Click Wheel into disk mode
Before placing the iPod into disk mode, you should verify that it is charged.
Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center. If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Important: If your iPod is frozen or won't turn on, it
may be because iPod is paused or the Hold switch is in the locked
position. If so, a lock symbol appears on the screen. Slide the Hold
switch to the unlocked position and check the screen.
Resolution
If you experience any of the above issues, try the following steps:
hidden).
If
needed.
After
1.
If
needed.
If your iPod is frozen or won't turn on, the steps to reset it vary by model.
hidden).
If
needed.
After
1.
If
needed.
hidden).
If
needed.
After
1.
If
needed.
Green and ORANGE? orange indicates the iPod is searching for music.
UNDERSTAND this- when you play music in the iTunes app., you are hearing the music in your computer not the iPod.
1) Install the latest iTunes application.
2) Do a restore
3) sync your iPod
hai,
i am preetha.My ipod shuffle will not play any music.When i press any buttons it just blinks on the green and orange light why is this? i have put music on it and charged it.plz tell what to do.
