Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
Posted on Jan 03, 2009
50" Magnavox Plasma TV will not turn on - Red LED blinking 4x
I have a 50" Magnavox Plasma (Model# 50MF231D/37). For the past few days it has been slow to bring up a picture. I'll get sound immediately but it would take a couple of minutes for the screen to "warm up". This morning, the TV will not turn on at all. I push the power button on the side of the TV, the light goes green like it's going to turn on and then the green light changes into a red light that blinks 4 times. I've gone onto the Magnavox website to troubleshoot my problem. They suggested I perform a software update. Well, I tried that and the TV goes into the blinking red light mode before the software update has a chance. I've owned the TV for about 1.5 yrs and I bought it from Wa-Mart for a steal because it was a display model. I'm sure that in itself creates it's own problems. I bought an extended warranty, but if it is a simple fix, I'd rather not send my TV out for lengthy repairs. The BCS National Title Game is next Thursday! :o) Thanks! Moriah
  • 3 more comments
  • Anonymous Apr 01, 2009
    I have had my TV for 1 yr and 5 months and my TV starting doing the same.... ONE TV repair stated that I needed and entire power board which will cost me 700-800, until I read this info.... Thanks and I can talk like I know something. I bet I will be getting this fixed with in days....
  • Anonymous Apr 09, 2009
    i have the same problem with blinking lights and the and the turn on . need some help finding the right parts on the power board.
  • ghugo1428 Apr 23, 2009
    i have a 42" magnavox plasma.i cant turn on .a red blinking led is on.....cant it get fix ?intructions please.... thanks!♥DAYMY♥
  • mrsortmudd12 Oct 26, 2009
    Have a 50" Plasma with bliking red light on front of tv. Will not turn on at all. I have unplugged and plugged it back in until I am blue in the face. It worked the first couple of times, but now it won't come on at all. Can someone help me, so that I can tell my husband how to fix this problem? We don't want to buy another TV.
  • schiefed01
    schiefed01 Aug 15, 2012
    Great posts...followed the advice of many as well as the youtube posts...and for $5 for two capacitors my TV's back in working order.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13940
Points
26
When you have the red light that blinks four times on the 50" Magnavox Plasma Model 50MF231D/37, you should look for the capacitors on the power board in the center of the of the TV. Look for two 3300uf, 10V, 105c capacitors that have a build up of pressure that has caused the top of the capacitor to look rounded instead of the flat top that will be on all of the other capacitors. Changing these two capacitors fixed the problem of the TV not coming on.
I had more trouble finding the capacitors than changing them. I could not find them locally so I went to an on-line electronics supply store where they were $1.65 each and $8.99 to ship.
Anonymous
Level 1:
New Friend:
  • Posted on Nov 12, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13940
Points
26
I replaced both bulged or rounded top capacitors like suggested and now it works great! I just wanted to say thanks to everyone that posted a solution and also post a picture of the capacitors location.
50
  • Anonymous Aug 27, 2010
    Having an issue finding these capacitors online...anyone have a website they can refer me to?
  • bamagirlmel Dec 08, 2011
    This picture is acurate, I used it today and fixed my t.v. in less than an hour. Removing the 40 some torx screws took the longest.once inside there are 6 or 8 phillips screws to take out and 4 electrical plugs to disconnect and the board panel is out. Jay tronix in rockford illinois has the capacitors,2 were about 9 bucks. (The capacitor numbers are correct as well) I found a local t.v. repair shop,mera's, that unsoldered the old 2 and reinstalled the new ones for 25 bucks. The solder iron would have ran me that @ radio shack. Best buy and other in home service companies wanted 150 dollars just to trouble shoot it. So the 2 weeks I had spent unnpluging my t.v. and waiting for the red flashing light to clear and then trying to get it to turn on were a waste of time once I realized how easy this was today. Thanks for the picture and everyones advise. Good luck. You will be your own repair man before you know it...!
Summer Jones
Level 1:
  • Posted on Aug 27, 2009
Summer Jones
Contributor
Level 1:
Answers
Questions
0
Helped
13940
Points
8
Thanks to the guy that said to make the tent and use the hairdryer to warm it up in order to turn it on. For a temporary fix it worked perfect. As for buying the 3300uf, 10V, 105c capacitors I went to Ebay and bought 12 for $5. My husband and I also bought a soldering iron and soldering pump at Radioshack for about $18. We had never used a soldering iron but found it to be very easy. Removing all the screws from the back of the TV was more time consuming.
  • Anonymous Feb 02, 2011
    Could someone please post the link as to where we can find these capacitors online? I would greatly appreciate it!
    Thanks.
Anonymous
Level 1:
  • Posted on May 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13940
Points
7
I, too had the blinking red light problem, and as stated above, just find the 2 bad capacitors and replace them.. worked for me!
Anonymous
Level 1:
  • Posted on Jul 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13940
Points
Where did you find the capacitors
Anonymous
Level 1:
  • Posted on Oct 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13940
Points
Listen to the people who mentioned the capacitors....I bought some off of ebay...bought a soldering iron and pump at radio shack and just fixed my T V. As mentioned....the screws take forever to take out and put in...all together took me just under 2 hrs by myself. Desoldering and soldering were easy. Remove the circuit board screws to expose the side you need to desolder/solder new capacitors. DO NOT just rip the old capacitors off and make sure you have the right polarity when you put new ones back in.....positive and negative
gysgt2u1
Level 1:
  • Contributor 35 Answers
  • Posted on Feb 16, 2009
gysgt2u1
Contributor
Level 1:
Answers
35
Questions
Helped
26198
Points
44
Have 2 50" Magnavox plasmas same model. Fixed both for a few bucks. I can turn them on and off and on and off at leisure. No more blinking red LED.
The SW upgrade thats pretty commical when the TV won't turn on. Work on the sortware upgrade after you fix this. Never turning your tv off again is not a fix. I admit though I did this for 2 weeks and I wanted to strangle my sister for turning it off when she came to visit. LOL 1 year later I am viewing them again. I will send pics of what to look for and instructions...
gysgt2u2@yahoo.
    I just emailed your yahoo address (assuming it is [email protected]) regarding sending the pictures and instructions. Please kindly post it if at all possible.
    Thank you so much,
    Anu
Anonymous
Level 1:
New Friend:
  • Posted on Nov 22, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13940
Points
Thanks to everyone that posted here. You saved me a lot of money. I have never soldered anything before and was a little apprehensive. I followed the advice above and much to my surprise, i did it. I did buy capacitors online that were a little larger in size than the original ones, I did this by accident but made them work. At the end of the day I spent 30.00 including a soldering gun, desoldering wick and capacitors. Careful on the size ( it definitely makes it harder to fit) and watch for positive and negative sides.
Anonymous
Level 1:
New Friend:
  • Posted on Feb 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13940
Points
Dear readers,
I found a bunch of videos on youtube for repairing the magnavox plasma. Here they are:
http://www.youtube.com/watch?v=-ueBrD55Idk
http://www.youtube.com/watch?v=OsJSzYVUWVA
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
On the third link I actually found the exact part number for the capacitors. You can order them here like he did:
http://search.digikey.com/scripts/DkSearch/dksus.dll?vendor=0&keywords=CAP+3300uF+10V+elec+EB+radial
I hope this helps!
Anonymous
Level 1:
  • Posted on Apr 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13940
Points
I just replaced the 2 capacitors and the tv is working great thank you!
  • 1 more comment
  • Anonymous Nov 25, 2010
    Replacing the capacitors does work but if you are not an expert at soldering I would recomend replacing the power supply board. I found a new one for 100$, it was more expensive than the 50$ in supplies to do the capacitor but way easier to replace (just a pluging in a few cabels and putting in some screws) then the capacitors would have been.
  • fightingi986 Dec 17, 2010
    WHERE DID YOU FIND A POWER SUPPLY BOARD?
  • wtldwg Jan 18, 2011
    where did you find your replacement powerboard?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
14893
Points
Plasma tv 50'' inch before i start tv red light go on then tv wont start i unpluged tv few times then stars agin
Anonymous
Level 1:
  • Posted on Jan 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13940
Points
You have to make a tent for your tv and put some small heater inside (be careful), and bring the temp of your tv up and it will turn back on if you unplug it till the red lights stop, then plug it back in and wait for the green light to go out, when it does hit the power button on the remote. you should wait for the tv to be warm before you try and repeat till it works. then NEVER TURN IT OFF AGAIN! I have the same tv , and the problem gets worse if you turn the tv off ,all you will get is the red light
    Scroll down to solution 10 before you make your judgement and read my comment there. That one was the most informative and helped me.
Anonymous
Level 1:
New Friend:
  • Posted on May 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13940
Points
I can tell you 100% you have to capacitors that are bad they are on the power board side by side there 2200uf 10volt caps and i would suggest you upgrade them to 2200uf 25volt caps
Anonymous
Level 1:
New Friend:
  • Posted on Jan 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13940
Points
Obviously having the same root problem, I ordered and changed the bulging capacitors. Did not solve the problem, as the problem is exactly the same.
I have found on Ebay the circut board LJ44-00118A.
Would this be considered the next cost-effective option to solving the problem before trashing the 50" (Model# 50MF231D/37) and buying new?
HELP Please!
Does the Blinking Light on the Asic Main logic board mean bad Logic Board?
Check all the capacitors one might be bad find out if it is bad it should bulge on top of the capacitors
10helpful
2answers
We have a Magnavox, 50 inch plasma TV, model 50MF231D/37. Recently when the TV is powered off and an attempt to power it back on again has been made, we get a red blinking light. The light blinks six...
Your problem is caused by a power supply issue it sounds like a capacitor is leaking or has vented and will need to be replaced if your comfortable you could check the power board for a can shaped electroletic cap that has vented it will be puffed up on the top the value is printed on the side you can or have someone replace it that should take care of your problem the power board is the one where the AC cord plugs to or leads to
1helpful
I have a Magnavox 50MF231D/37 plasma tv that won't turn on. I have to unplug it and let it sit. The green LED light changes to red and flashes. I upgraded the software but still have the problem.
you have some bad caps on the power supply board these can like devices will have a puffed up top where it vented the value is written on the side of the part
2answers
1helpful
I have 50 in plasma phillips magnavox 50mf231d-37, will not come on red light flahses 4 times
this is some info that some one else had found
get a memory stick( flash drive) and up load their soft ware from their site. I plug the stick into the computor and uploaded the software. I then plugged the stick into my TV on the side. A screen came up and the software loaded on the TV successfully. The red light then turned to green. However, I now have to unplug and plug the TV several times for it to turn on. It works fine but once the TV is turns on, but when I turn it off and it cools for a while I have to repeat the same proceedure off plugging and unplugging
10helpful
12answers
Magnavox 50" plasma Won't Power on/Shut's off/Blinking red LED
The above fix, listed by Tom saved us!! We did as instructed and took off the back of our 50 inch Magnavox plasma tv. We were not sure what we were looking for so we googled capacitator (image) & there was a photo of a fried capacitator! Sure enough we noticed ours were "fried", we took out the board and went to an electronic supply store, bought the 2 capacitators ($2.00 each!!) and then found someone who did tv repair to sauter the new capacitators onto the board. (It is important someone who know how to sauter and recognizes polarity do do this for you) All in all we fixed this following the above instructions for $34.00 and our time. For a month we were told to spend hundreds getting a new power board!
Kudos to you Tom & thanks so much!!
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
