Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
Carl Voelker Posted on Oct 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why rapid fuel consumpsion on the husqvrana 455 rancher?
Andrew White
Level 3:
  • Husqvarna Master 2,239 Answers
  • Posted on Oct 18, 2012
Andrew White
Husqvarna Master
Level 3:
Answers
2239
Questions
Helped
910929
Points
5950
There are only a few reasons, either the saw is running too rich on the carb settings ( i think you would know notice this due too poor engine performance ) or the air filter is blocked ( again this would effect engine performance ) or the the tank is leaking.
5 Related Answers
Anonymous
  • 2220 Answers
  • Posted on Sep 25, 2009
SOURCE: Fuel Mixture Husqvarna 455 Rancher Chain Saw
Page 17 of your Operator's Manual says 50:1.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Anonymous
  • Posted on Aug 03, 2009
SOURCE: my 455 rancher won't maintain power. I have
If you have been running ethnol mix in your saw there is a good chance that your fuel vent line is plugged. Loosen your fuel cap and start saw on its side and see if it runs. If it does you will have to clean your fuel vent.
spekgt
Filipe Mendonca
  • 60 Answers
  • Posted on Aug 29, 2009
SOURCE: 455 rancher chainsaw does not pump oil to the chain
If you look under the machine by the chain you'll see a flat head screw (next to the sprocket) which controls the bar and chain oil flow . Try to turn the screw and check if there's any oil flow to the chain . If not you will need to replace the oil pump (part # 537 10 55-02 which will cost you about $35.00) Hope this help
Anonymous
  • 2220 Answers
SOURCE: What is Fuel Mixture Husqvarna 455 Rancher Chain
Duplicate post Close/delete
Anonymous
  • 2220 Answers
  • Posted on Mar 22, 2010
SOURCE: magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
What is the gas / oil ratio mixture for husqvarna 455 rancher model ?
50:1 that's 2.6 ounces of 2-stroke oil (preferably with fuel stabilizer) to one gallon of gas. I recommend using 89 octane gasoline for all small engines. It has little or no ethanol in it, as opposed to the 10% typical in 87 or 86 octane fuel. This will prevent a lot of fuel issues, especially if you are not using the tool daily or at least weekly.
Not getting gas to the carb
Possibly dirt or other clog in the fuel line!
455 rancher runs for about 5 min. than stalls and wont start until cold than problem repeats
Sounds like a fuel problem. Something might be expanding as the saw warms up and is cutting off the fuel or introducing an air leak. Carby may require a new kit and check the fuel line
Husqvarna 455 rancher has no power at full throttle, but will start and idle normal.
Check for plugged fuel filter, air cleaner, and muffler. Check the fuel lines for decay or other damage. Check the chain for proper oiling and not so tight that you can't turn it by hand. Hope this helps!
Husqvarna 455 rancher . it has low compression and no fuel to plug . wont start but piston and rings are fine .Help
it could be the small gasket between the head and carb. they are also bad about the fuel line coming out of the tank gettin rubbed and making a small hole or pinched.
455 rancher engine bogging down and starting to smoke
Make sure you are using the correct fuel mix.
Check fuel tank vent, prone to blocking an can effect the performance
Clean air filter, check Spark plug.
2helpful
2answers
I have a husqvarna 455 rancher. It was working
Take it right back to repair shop and have them fix under their warranty.
It is possible the fuel hasn't got to the carbureator due to plugged fuel filter or fuel finder OR an air leak in the fuel hose.
I am getting fire on my 455 rancher BUT IT WILL NOT START
you need turn off you choke one's its fired up... otherwise it will flood the saw with too much fuel...
2answers
My 455 rancher won't maintain power. I have
if its over a year old and you used other than 93 octane, you need to rebuild the c arb, i did an runs like new
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
