SOURCE: removal of cross bars on equinox
most roof racks if you undo the adjustemt screws / knobs at either end of the crossbars it will release the crossbars
SOURCE: 2001 BMW 325 how do i charge the battery
If you look around the engine compartment you will see a sort of large silver nut on one of the inner wings. This is for the negative lead. Now if you search around a bit more you will find a sort of square black cover with an arrow type electrical sign. Lift the top off the cover and you will see a similar type nut. This is the positive. i.e. you do not need to access the battery tocharge or jump start the car.
Cheers John
Have you tried the dealer or wholesale sites like http://www.mitsubishi-parts-dealer.com/ ?
SOURCE: Can't secure the front cross rail forward for bike rack
dear friend-the roof rack on a sante fe can not be moved.should you attempt that you will have constant rattles on your roof.i can surgest.that you modify your bike rack.
SOURCE: How do you remove the rubber in the fix points to
You do not want to remove this rubber. There may not be custom designed roof bars to fit this model. If you really wanted to I guess you could use sheet metal screws to install brackets under the edges of the door sills.
