FreeMotion I7.7 Incline Trainer Treadmill Logo
Anonymous Posted on Oct 07, 2012
Our Freemotion 17.7 Incline Trainer is reading; Serching for motor controler
Our Freemotion Incline Trainer Treadmill Model #FMTK74810.0 won't increase speed but when we hit the Up arrow the fan will blow faster??
It sounds like there might be a issue with the control board of your treadmill. The control board is responsible for managing all of the functions of the machine, including the speed of the belt and the operation of the fan. If the fan speed is increasing when you press the up arrow, but the belt speed is not, it suggests that there is a problem with the control board that is preventing it from sending the correct signals to the motor to increase the speed.
To resolve this issue, you may need to have a technician take a look at the control board and repair or replace it if necessary. Before calling for service, you can also try resetting the treadmill by unplugging it from the wall for a few minutes and then plugging it back in. This can sometimes resolve issues with the control board. If the problem persists, I would recommend contacting the manufacturer or a professional repair service for assistance.
My freemotion i5.3 incline trainer shut off while I was walking on it and now it will not turn back on.
I have a Freemotion i5.3 Incline Trainer. When I run on it at 4+ MPH it makes loud bangs when my foot land on the platform. I usually walk on it at higher incline and just recently started running on it. The bangs are much louder at 0% incline than at higher inclines for the same speed. What might be the problem?
Incline not moving
Try to do the following hope it will solve the problem.
if its doesn't solve the problem then the the incline motor or the control panel is faulty.
HOW TO USE THE SETTINGS MODE T
he console features a settings mode that allows you to connect your incline trainer to your own wireless network and to log in to your iFit Live account. The settings mode also allows you to turn on and turn off the display demo mode. You may also be able to select the unit of measurement.
Select the settings mode.
Insert the key into the console . Next, select the start menu. Then, press the i button in the lower right corner of the screen to select the settings mode.
Select the maintenance mode.
Press the Maintenance button in the lower right corner of the screen to enter the maintenance mode.
Calibrate the incline system of the incline trainer.
Press the Calibrate Incline button. The incline trainer will automatically rise to the maximum incline level, lower to the minimum incline level and then return to the starting position. This will recalibrate the incline system. Press the Begin button to calibrate the incline system or the Cancel button to return to the maintenance mode. When the incline system is calibrated, press the Back button. IMPORTANT: Keep pets, feet, and other objects away from the incline trainer while the incline is calibrating. In an emergency, pull the key from the console to stop the incline calibration.
Restore factory defaults.
If necessary, press the Restore Defaults button to reset the firmware to the original factory firmware. This will erase all firmware updates that you have downloaded. Press the Begin button to restore the default firmware or the Cancel button to return to the maintenance mode. When the restoration is complete, the words PLEASE CYCLE POWER will appear in the grey box. Press the power switch into the off position. Wait for several seconds, and then press the power switch into the reset position. It may take a minute for the console to be ready for use.
Exit the maintenance mode.
To exit the maintenance mode, press the Back button repeatedly.
www.electro-medical.blogspot.com
Tt30 is stuck at 3% incline and will not speed up or slow down. It also beeps continually and displays SB for about 5 seconds when first turned on. I tried the recalibration procedure and it does not...
please RUN the software calibration for easy diagnostic and fix it.
go to HOOD cover motor, and follow the steps, or ready your owner manual
God bless you
Incline not working
The Trainer is reading; Serching for motor controler
We have a Free Motion Tt30 Incline Trainer making a loud noise that sounds like a bearing going bad, then the noise stops. Do you have any repair suggestions?
1) Lube the machine see the video and use the common sense, this happen because the lack of maintenancae according with the instr. manual. Shut down the machine for to protect the electronic system.
2) Lube the rollers bearing too, very well.
3) Test the input voltage motor, if there are the motor NEED repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
God bless you
Freemotion treadmill incline not going all the way
The problem is either in the lower control board or the lift motor. I would start by replacing the lift motor. Then if that does not fix it, replace the lower control board.
Will my ifit treadmill card work in an incline
Technically, the Incline Trainer and the treadmill are two different type of machines. The incline trainer raises much higher so the card that is designed for the treadmill will not work on the incline trainer unfortunately.
Top FreeMotion Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
