20 Most Recent Nordic Track NordicTrack X7i Incline Trainer Questions & Answers
Try to do the following hope it will solve the problem.
if its doesn't solve the problem then the the incline motor or the control panel is faulty.
HOW TO USE THE SETTINGS MODE T
he console features a settings mode that allows you to connect your incline trainer to your own wireless network and to log in to your iFit Live account. The settings mode also allows you to turn on and turn off the display demo mode. You may also be able to select the unit of measurement.
Select the settings mode.
Insert the key into the console . Next, select the start menu. Then, press the i button in the lower right corner of the screen to select the settings mode.
Select the maintenance mode.
Press the Maintenance button in the lower right corner of the screen to enter the maintenance mode.
Calibrate the incline system of the incline trainer.
Press the Calibrate Incline button. The incline trainer will automatically rise to the maximum incline level, lower to the minimum incline level and then return to the starting position. This will recalibrate the incline system. Press the Begin button to calibrate the incline system or the Cancel button to return to the maintenance mode. When the incline system is calibrated, press the Back button. IMPORTANT: Keep pets, feet, and other objects away from the incline trainer while the incline is calibrating. In an emergency, pull the key from the console to stop the incline calibration.
Restore factory defaults.
If necessary, press the Restore Defaults button to reset the firmware to the original factory firmware. This will erase all firmware updates that you have downloaded. Press the Begin button to restore the default firmware or the Cancel button to return to the maintenance mode. When the restoration is complete, the words PLEASE CYCLE POWER will appear in the grey box. Press the power switch into the off position. Wait for several seconds, and then press the power switch into the reset position. It may take a minute for the console to be ready for use.
Exit the maintenance mode.
To exit the maintenance mode, press the Back button repeatedly.
www.electro-medical.blogspot.com
Nordic Track... | Answered on Aug 31, 2015
Hello
The servo motor which changes the resistance (under the plastic covers) is winding the cable in the wrong direction. Release tension on the cable by pulling the magnets away from the fly wheel and flip the cable off the the servo motor pulley, this will allow the cable to be pulled in the correct direction.
Nordic Track... | Answered on May 19, 2019
Controller . I aman authourised repairer for the brand in Australia .
Nordic Track... | Answered on Apr 28, 2019
Try resetting the router.
Nordic Track... | Answered on Apr 25, 2019
Try spraying silicone spray under the belt. It worked on mine. You can buy spray cans from a Hardware or Bunnings etc.
Nordic Track... | Answered on Apr 07, 2019
It would appear via one video and someone else's post that it is at the front of the machine, directly above the crossbar that contacts the floor.
Nordic Track... | Answered on Mar 04, 2019
My treadmill has a little steel rod that flips in and holds the bed up' When you want the bed down you pull the rod back out and it lets it come back down.
Nordic Track... | Answered on Feb 17, 2019
Nordic Track NordicTrack X7i Incline Trainer Logo
6 questions posted
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Nordic Track Exercise & Fitness
Most Popular Question
incline not moving
  • Exercise & Fitness
