Televison & Video Logo
Posted on Dec 29, 2008
Struggling with Sky remote codes for new Samsung TV LE32A457
Using a Sky Box and Controller (a few years old now)....not Sky + or Sky HD.
Havve spoken to Sky and Samsung a few times now and neither able to offer a correct code
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Dec 29, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
19242
Points
39
0060, 065, 584, 037, 245, 476, 398, 516, 292, 318,037
these are samsung codes for sky remote
good luck
1helpful
3answers
What is the sky remote code for a Seiki TV
Firstly you need to check if the sky remote is rev10 or later. Anything less will not work.
The code is 2992 or 3992.
My remote is rev10 and code 2992 worked.
3helpful
3answers
Sky navigtor tv code tv samsung
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 4 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
  • If this works try the other TV functions.
  • If these work then the correct code has been selected.
  • It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
Common Sky Remote Codes for your TV
Aiwa 0106
Akai 0098
Akura 0042
Alba 0043
Amstrad 0063
Baird 0117
Bang & Olufsen 0118
Bpl 0115
Beko 0125
Beon 0899
Brionvega 0147
Bush 0157
Crown 0225
Daewoo 0092
Decca 0244
Dual 0257
Ferguson 0293
Fidelity 0294
Finlandia 0296
Finlux 0297
Fisher 0154
Funai 0179
Genexxa 0330
Goldstar 0056
Goodmans 0335
Granada 0340
Grundig 0345
Harwood 0361
Hinari 0365
Hitachi 0145
Itt 0384
JVC 0053
Loewe 0442
Matsui 0477
Memorex 0037
Metz 0491
Minoka 0921
Mitsubishi 0150
Nei 0514
Nikkai 0528
Nokia 0536
Nordmende 0537
Orion 0549
Panasonic 0051
Philips 0081
Pioneer 0166
Protech 0595
Pye 0600
Roadstar 0625
Saba 0645
Saisho 0649
Salora 0651
Samsung 0060
Sanyo 0159
Schneider 0665
Seleco 0672
Sharp 0093
Siemens 0680
Sony 0000
Soundwave 0702
Tandy 0741
Tatung 0049
Techincs 0250
Telefunken 0757
Thomson 0771
Thorn 0772
Thorn-ferguson 0936
Toshiba 0156
HD not working.
Have you connected it Via HDMI? if the screen is still connected via Scart then that is the problem.
Sky hd remote code needed please
Sky High Definition SkyHD uses a new design of Slim line remote control. The Default TV code pre-programmed into the RCU is now for Phillips and is (0)065. The SkyHD RCU is programmed in the usual manner using either the instructions in the Digital Installation Manual or via the Sky Customer Service option in the Interactive on-screen menu.
The SkyHD RCU can also be programmed to operate Sky+ boxes as well as SkyHD:
Press the TV button.
Press and hold SELECT and i together until the LED flashes twice.
Press the number button 1 and then press SELECT.
(Obviously you can't have a SkyHD and a Sky+ Digibox both in the same room).
Note: To re-programme the RCU for Sky HD box operation only, repeat the above process pressing the 2 button in step three.
Keep pressing HELP and waiting a few seconds until you find the correct command that activates the AV source you require then press SELECT.
The HELP button will now directly activate the chosen AV source instead of toggling through the alternative options to reach it.
There are 18 AV source commands to be tried before the RCU blinks 3 times to indicate it is out of options.
The Sky Guide buttons (SKY, tv guide, box office, services & interactive) can now be directed to use the same AV source as the newly programmed HELP button.
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice.
The Sky Guide buttons will now instruct the TV to switch to the desired AV source and the RCU will be in Sky Mode.
Discussion here: http://www.digitalspy.co.uk/forums/showthread.php?t=944054
You can also use a Sky+ remote to control a SkyHD digibox.
See codes page for SkyHD
2helpful
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
15helpful
4answers
SKY REMOTE NOT WORKING WITH MY NEW LG 42LH3000
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
31helpful
4answers
42LH3000 I CANT GET MY SKY REMOTE TO WORK WITH THIS TV. I NEED A CODE IF THERE IS ONE
Once you have the ver 8 controller - code 1176 should work
2helpful
4answers
My sky remote has stopped working on my samsung tv
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
1helpful
Sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
