SOURCE: Sony KDF-E50A10
If the lamp is new it could be the ballast the one is supply high voltage for the lamp you can order that ballast from Sony
Check the lamp if is not damage any where
Cheers
SOURCE: I have the same problem as robgon52 dated 1/25/09.
You need to replace Lamp only as existing lamp is weak in result and causing such symptoms.
Ballast supply is fine and working.
Thanks.
